[postgis-users] postgis installation on current Postgresql (8.1) database (on Debian)
alex bodnaru alexbodn at 012.net.il
Fri Jan 20 09:59:37 PST 2006
hi steve,
sorry to have been unavailable for the last days.
this is the procedure to follow (at least best to try).
nb. i understand ubuntu doesn't have every postgresql version, so please
remove missing ones from files in ./debian/control.source.
your feedback will be highly welcome.
alex
Stephen Woodbridge wrote:
> Hi Alex,
> I am running a debian sarge amd64 system and have grabbed the sid source
> for postgresql and build it. Is there a package for postGIS-1.1.0 that I
> can download and build for dpkg?
> It looks like I might be able to follow the pocedure your listed below.
> Is this correct? I have the patch file you posted before.
> Thanks,
>   -Steve
> alex bodnaru wrote:
>> assad,
>> your ./configure output seems a little wird for a clean postgresql sarge
>> installation.
>> the procedure below will possibly help. if still in problem, you might
>> need to have a better backported postgresql for sarge, or upgrade debian.
>> please apply this diff to the *clean* postgis source:
>> cd postgis_source_root
>> zcat the_attached_file | patch -p1
>> # you should have ./debian subdirectory in postgis_source_root
>> chmod ug+x debian/rules
>> dpkg-buildpackage -rfakeroot
>> good luck,
>> alex
>> Assad Jarrahian wrote:
>>> Alex,
>>>  I am running sarge. How do I get a hold of that package.
>>> I looked at
>>> http://pkg-grass.alioth.debian.org/cgi-bin/wiki.pl/PackageList
>>> and it says postgis (now uninstallable)
>>> thanks for your help alex.
>>> -assad
>>> On 1/13/06, alex bodnaru <alexbodn at 012.net.il> wrote:
>>>> what debian version do you have?
>>>>> I took a closer look. The directory /usr/include/postgresql/ exists
>>>>> and postgres.h is in that directory.
>>>>> There is no 8.1 directory.
>>>>> How do I mend the problem (tell pg-config that the directory is
>>>>> somewhere else)
>>>>> much thanks and sorry for the initial lookover of the file existing.
>>>>> -assad
>>>>> On 1/13/06, strk at refractions.net <strk at refractions.net> wrote:
>>>>>> This is your problem:
>>>>>> gcc -DUSE_VERSION=81 -DPOSTGIS_LIB_VERSION='"1.1.0"'
>>>>>> -DPOSTGIS_VERSION='"1.1 USE_GEOS=1 USE_PROJ=1 USE_STATS=1"'
>>>>>> -DPOSTGIS_SCRIPTS_VERSION='"1.1.0"' -DPOSTGIS_BUILD_DATE='"2006-01-12
>>>>>> 16:30:40"' -I/usr/local/include -DUSE_PROJ
>>>>>> -I/usr/include/postgresql/8.1/server -DAUTOCACHE_BBOX=1  -DUSE_STATS
>>>>>> -Wall -g -O2 -fPIC -fexceptions -DUSE_GEOS
>>>>>> -I/usr/local/include     -c
>>>>>> -o liblwgeom.o liblwgeom.c
>>>>>> In file included from liblwgeom.c:26:
>>>>>> lwgeom_pg.h:4:22: error: postgres.h: No such file or directory
>>>>>> Do you stil confirm that this file exist:
>>>>>>      /usr/include/postgresql/8.1/server/postgres.h
>>>>>> --strk;
>>>>>> On Fri, Jan 13, 2006 at 01:15:45AM -0700, Assad Jarrahian wrote:
>>>>>>> strk, stefano, david .... please help. Am stuck.
>>>>>>> Thanks.
>>>>>>> -assad
>>>>>>> On 1/12/06, Assad Jarrahian <jarraa at gmail.com> wrote:
>>>>>>>> I pasted the complete output below. Thanks for your help.
>>>>>>>> make -C lwgeom
>>>>>>>> make[1]: Entering directory `/packages/postgis-1.1.0/lwgeom'
>>>>>>>> cpp -P -traditional-cpp -DUSE_VERSION=81 lwpostgis.sql.in | sed -e
>>>>>>>> 's:@MODULE_FILENAME@:\$libdir/liblwgeom.so.1.1:g;s:@POSTGIS_VERSION@:1.1
>>>>>>>> USE_STATS=1:g;s:@POSTGIS_SCRIPTS_VERSION@:1.1.0:g;s/@POSTGIS_BUILD_DATE@/2006-01-12
>>>>>>>> 16:30:40/g' | grep -v '^#' > ../lwpostgis.sql
>>>>>>>> /usr/bin/perl ../utils/postgis_proc_upgrade.pl ../lwpostgis.sql >
>>>>>>>> ../lwpostgis_upgrade.sql
>>>>>>>> -DUSE_STATS
>>>>>>>> -o measures.o measures.c
>>>>>>>> -DUSE_STATS
>>>>>>>> -o box2d.o box2d.c
>>>>>>>> -DUSE_STATS
>>>>>>>> -o ptarray.o ptarray.c
>>>>>>>> ptarray.c: In function 'ptarray_segmentize2d':
>>>>>>>> ptarray.c:223: warning: dereferencing type-punned pointer will
>>>>>>>> break
>>>>>>>> strict-aliasing rules
>>>>>>>> break
>>>>>>>> -DUSE_STATS
>>>>>>>> -o lwgeom_api.o lwgeom_api.c
>>>>>>>> lwgeom_api.c: In function 'lwgeom_getpoint_inspected':
>>>>>>>> lwgeom_api.c:974: warning: pointer targets in assignment differ
>>>>>>>> in signedness
>>>>>>>> lwgeom_api.c:981: warning: pointer targets in passing argument 1 of
>>>>>>>> 'lwpoint_deserialize' differ in signedness
>>>>>>>> lwgeom_api.c: In function 'lwgeom_getpoly':
>>>>>>>> lwgeom_api.c:1051: warning: pointer targets in assignment differ
>>>>>>>> in signedness
>>>>>>>> lwgeom_api.c:1057: warning: pointer targets in passing argument
>>>>>>>> 1 of
>>>>>>>> 'lwpoly_deserialize' differ in signedness
>>>>>>>> lwgeom_api.c: In function 'lwgeom_getpoly_inspected':
>>>>>>>> lwgeom_api.c:1069: warning: pointer targets in assignment differ
>>>>>>>> in signedness
>>>>>>>> lwgeom_api.c:1076: warning: pointer targets in passing argument
>>>>>>>> 1 of
>>>>>>>> lwgeom_api.c: In function 'lwgeom_getsubgeometry':
>>>>>>>> lwgeom_api.c:1097: warning: pointer targets in assignment differ
>>>>>>>> in signedness
>>>>>>>> lwgeom_api.c:1099: warning: pointer targets in return differ in
>>>>>>>> signedness
>>>>>>>> lwgeom_api.c: In function 'printPA':
>>>>>>>> lwgeom_api.c:1636: warning: pointer targets in assignment differ
>>>>>>>> in signedness
>>>>>>>> lwgeom_api.c:1637: warning: pointer targets in assignment differ
>>>>>>>> in signedness
>>>>>>>> lwgeom_api.c: In function 'printBYTES':
>>>>>>>> lwgeom_api.c:1674: warning: pointer targets in passing argument
>>>>>>>> 2 of
>>>>>>>> 'deparse_hex' differ in signedness
>>>>>>>> lwgeom_api.c: In function 'pglwgeom_from_ewkb':
>>>>>>>> lwgeom_api.c:1775: warning: pointer targets in passing argument
>>>>>>>> 2 of
>>>>>>>> lwgeom_api.c: In function 'lwgeom_typeflags':
>>>>>>>> lwgeom_api.c:2000: warning: pointer targets in return differ in
>>>>>>>> signedness
>>>>>>>> lwgeom_api.c: In function 'parse_lwgeom_wkt':
>>>>>>>> lwgeom_api.c:2242: warning: pointer targets in passing argument
>>>>>>>> 1 of
>>>>>>>> 'parse_lwg' differ in signedness
>>>>>>>> lwgeom_api.c: In function 'box2df_to_box3d':
>>>>>>>> lwgeom_api.c:220: warning: 'result.zmin' is used uninitialized
>>>>>>>> in this function
>>>>>>>> lwgeom_api.c:220: warning: 'result.zmax' is used uninitialized
>>>>>>>> in this function
>>>>>>>> lwgeom_api.c:220: warning: 'result.ymax' is used uninitialized
>>>>>>>> in this function
>>>>>>>> lwgeom_api.c:220: warning: 'result.xmax' is used uninitialized
>>>>>>>> in this function
>>>>>>>> lwgeom_api.c:220: warning: 'result.ymin' is used uninitialized
>>>>>>>> in this function
>>>>>>>> lwgeom_api.c:220: warning: 'result.xmin' is used uninitialized
>>>>>>>> in this function
>>>>>>>> -DUSE_STATS
>>>>>>>> -o lwgeom.o lwgeom.c
>>>>>>>> lwgeom.c: In function 'lwgeom_to_ewkb':
>>>>>>>> lwgeom.c:409: warning: pointer targets in return differ in
>>>>>>>> signedness
>>>>>>>> -DUSE_STATS
>>>>>>>> -o lwpoint.o lwpoint.c
>>>>>>>> -DUSE_STATS
>>>>>>>> -o lwline.o lwline.c
>>>>>>>> -DUSE_STATS
>>>>>>>> -o lwpoly.o lwpoly.c
>>>>>>>> lwpoly.c: In function 'lwpoly_deserialize':
>>>>>>>> lwpoly.c:80: warning: pointer targets in assignment differ in
>>>>>>>> signedness
>>>>>>>> lwpoly.c:90: warning: pointer targets in assignment differ in
>>>>>>>> signedness
>>>>>>>> lwpoly.c:105: warning: pointer targets in passing argument 1 of
>>>>>>>> 'get_int32' differ in signedness
>>>>>>>> lwpoly.c:113: warning: pointer targets in passing argument 1 of
>>>>>>>> 'get_uint32' differ in signedness
>>>>>>>> lwpoly.c:121: warning: pointer targets in passing argument 1 of
>>>>>>>> lwpoly.c:124: warning: pointer targets in passing argument 1 of
>>>>>>>> 'pointArray_construct' differ in signedness
>>>>>>>> -DUSE_STATS
>>>>>>>> -o lwmpoint.o lwmpoint.c
>>>>>>>> -DUSE_STATS
>>>>>>>> -o lwmline.o lwmline.c
>>>>>>>> -DUSE_STATS
>>>>>>>> -o lwmpoly.o lwmpoly.c
>>>>>>>> -DUSE_STATS
>>>>>>>> -o lwcollection.o lwcollection.c
>>>>>>>> -DUSE_STATS
>>>>>>>> -o wktunparse.o wktunparse.c
>>>>>>>> -DUSE_STATS
>>>>>>>> -o lwgparse.o lwgparse.c
>>>>>>>> -DUSE_STATS
>>>>>>>> -o wktparse.tab.o wktparse.tab.c
>>>>>>>> wktparse.y: In function 'lwg_parse_yyparse':
>>>>>>>> wktparse.y:43: warning: pointer targets in passing argument 1 of
>>>>>>>> 'alloc_wkb' differ in signedness
>>>>>>>> -DUSE_STATS
>>>>>>>> -o lex.yy.o lex.yy.c
>>>>>>>> lex.yy.c:3044: warning: 'yyunput' defined but not used
>>>>>>>> -DUSE_STATS
>>>>>>>> -o vsprintf.o vsprintf.c
>>>>>>>> -DUSE_STATS
>>>>>>>> lwgeom_pg.h:5:29: error: utils/geo_decls.h: No such file or
>>>>>>>> directory
>>>>>>>> lwgeom_pg.h:6:18: error: fmgr.h: No such file or directory
>>>>>>>> lwgeom_pg.h:28: error: syntax error before 'getGeometryOID'
>>>>>>>> lwgeom_pg.h:28: warning: type defaults to 'int' in declaration of
>>>>>>>> 'getGeometryOID'
>>>>>>>> lwgeom_pg.h:28: warning: data definition has no type or storage
>>>>>>>> class
>>>>>>>> lwgeom_pg.h:35: error: syntax error before '*' token
>>>>>>>> lwgeom_pg.h:36: error: syntax error before 'box2df_to_box'
>>>>>>>> lwgeom_pg.h:36: warning: type defaults to 'int' in declaration of
>>>>>>>> 'box2df_to_box'
>>>>>>>> lwgeom_pg.h:36: warning: data definition has no type or storage
>>>>>>>> class
>>>>>>>> lwgeom_pg.h:37: error: syntax error before 'BOX'
>>>>>>>> lwgeom_pg.h:40: error: syntax error before 'BOX2D_same'
>>>>>>>> lwgeom_pg.h:40: warning: type defaults to 'int' in declaration
>>>>>>>> of 'BOX2D_same'
>>>>>>>> lwgeom_pg.h:40: warning: parameter names (without types) in
>>>>>>>> function declaration
>>>>>>>> lwgeom_pg.h:40: warning: data definition has no type or storage
>>>>>>>> class
>>>>>>>> lwgeom_pg.h:41: error: syntax error before 'BOX2D_overlap'
>>>>>>>> lwgeom_pg.h:41: warning: type defaults to 'int' in declaration of
>>>>>>>> 'BOX2D_overlap'
>>>>>>>> lwgeom_pg.h:41: warning: parameter names (without types) in
>>>>>>>> lwgeom_pg.h:41: warning: data definition has no type or storage
>>>>>>>> class
>>>>>>>> lwgeom_pg.h:42: error: syntax error before 'BOX2D_overleft'
>>>>>>>> lwgeom_pg.h:42: warning: type defaults to 'int' in declaration of
>>>>>>>> 'BOX2D_overleft'
>>>>>>>> lwgeom_pg.h:42: warning: parameter names (without types) in
>>>>>>>> lwgeom_pg.h:42: warning: data definition has no type or storage
>>>>>>>> class
>>>>>>>> lwgeom_pg.h:43: error: syntax error before 'BOX2D_left'
>>>>>>>> lwgeom_pg.h:43: warning: type defaults to 'int' in declaration
>>>>>>>> of 'BOX2D_left'
>>>>>>>> lwgeom_pg.h:43: warning: parameter names (without types) in
>>>>>>>> lwgeom_pg.h:43: warning: data definition has no type or storage
>>>>>>>> class
>>>>>>>> lwgeom_pg.h:44: warning: type defaults to 'int' in declaration
>>>>>>>> of 'BOX2D_right'
>>>>>>>> lwgeom_pg.h:44: warning: parameter names (without types) in
>>>>>>>> lwgeom_pg.h:44: warning: data definition has no type or storage
>>>>>>>> class
>>>>>>>> lwgeom_pg.h:45: error: syntax error before 'BOX2D_overright'
>>>>>>>> lwgeom_pg.h:45: warning: type defaults to 'int' in declaration of
>>>>>>>> 'BOX2D_overright'
>>>>>>>> lwgeom_pg.h:45: warning: parameter names (without types) in
>>>>>>>> lwgeom_pg.h:45: warning: data definition has no type or storage
>>>>>>>> class
>>>>>>>> lwgeom_pg.h:46: error: syntax error before 'BOX2D_overbelow'
>>>>>>>> lwgeom_pg.h:46: warning: type defaults to 'int' in declaration of
>>>>>>>> 'BOX2D_overbelow'
>>>>>>>> lwgeom_pg.h:46: warning: parameter names (without types) in
>>>>>>>> lwgeom_pg.h:46: warning: data definition has no type or storage
>>>>>>>> class
>>>>>>>> lwgeom_pg.h:47: error: syntax error before 'BOX2D_below'
>>>>>>>> lwgeom_pg.h:47: warning: type defaults to 'int' in declaration
>>>>>>>> of 'BOX2D_below'
>>>>>>>> lwgeom_pg.h:47: warning: parameter names (without types) in
>>>>>>>> lwgeom_pg.h:47: warning: data definition has no type or storage
>>>>>>>> class
>>>>>>>> lwgeom_pg.h:48: error: syntax error before 'BOX2D_above'
>>>>>>>> lwgeom_pg.h:48: warning: type defaults to 'int' in declaration
>>>>>>>> of 'BOX2D_above'
>>>>>>>> lwgeom_pg.h:48: warning: parameter names (without types) in
>>>>>>>> lwgeom_pg.h:48: warning: data definition has no type or storage
>>>>>>>> class
>>>>>>>> lwgeom_pg.h:49: error: syntax error before 'BOX2D_overabove'
>>>>>>>> lwgeom_pg.h:49: warning: type defaults to 'int' in declaration of
>>>>>>>> 'BOX2D_overabove'
>>>>>>>> lwgeom_pg.h:49: warning: parameter names (without types) in
>>>>>>>> lwgeom_pg.h:49: warning: data definition has no type or storage
>>>>>>>> class
>>>>>>>> lwgeom_pg.h:50: error: syntax error before 'BOX2D_contained'
>>>>>>>> lwgeom_pg.h:50: warning: type defaults to 'int' in declaration of
>>>>>>>> 'BOX2D_contained'
>>>>>>>> lwgeom_pg.h:50: warning: parameter names (without types) in
>>>>>>>> lwgeom_pg.h:50: warning: data definition has no type or storage
>>>>>>>> class
>>>>>>>> lwgeom_pg.h:51: error: syntax error before 'BOX2D_contain'
>>>>>>>> lwgeom_pg.h:51: warning: type defaults to 'int' in declaration of
>>>>>>>> 'BOX2D_contain'
>>>>>>>> lwgeom_pg.h:51: warning: parameter names (without types) in
>>>>>>>> lwgeom_pg.h:51: warning: data definition has no type or storage
>>>>>>>> class
>>>>>>>> lwgeom_pg.h:52: error: syntax error before 'BOX2D_intersects'
>>>>>>>> lwgeom_pg.h:52: warning: type defaults to 'int' in declaration of
>>>>>>>> 'BOX2D_intersects'
>>>>>>>> lwgeom_pg.h:52: warning: parameter names (without types) in
>>>>>>>> lwgeom_pg.h:52: warning: data definition has no type or storage
>>>>>>>> class
>>>>>>>> lwgeom_pg.h:53: error: syntax error before 'BOX2D_union'
>>>>>>>> lwgeom_pg.h:53: warning: type defaults to 'int' in declaration
>>>>>>>> of 'BOX2D_union'
>>>>>>>> lwgeom_pg.h:53: warning: parameter names (without types) in
>>>>>>>> lwgeom_pg.h:53: warning: data definition has no type or storage
>>>>>>>> class
>>>>>>>> lwgeom_pg.h:55: error: syntax error before 'LWGEOM_same'
>>>>>>>> lwgeom_pg.h:55: warning: type defaults to 'int' in declaration
>>>>>>>> of 'LWGEOM_same'
>>>>>>>> lwgeom_pg.h:55: warning: parameter names (without types) in
>>>>>>>> lwgeom_pg.h:55: warning: data definition has no type or storage
>>>>>>>> class
>>>>>>>> lwgeom_pg.h:56: error: syntax error before 'BOX3D_construct'
>>>>>>>> lwgeom_pg.h:56: warning: type defaults to 'int' in declaration of
>>>>>>>> 'BOX3D_construct'
>>>>>>>> lwgeom_pg.h:56: warning: parameter names (without types) in
>>>>>>>> lwgeom_pg.h:56: warning: data definition has no type or storage
>>>>>>>> class
>>>>>>>> lwgeom_pg.h:57: error: syntax error before 'BOX2DFLOAT4_ymin'
>>>>>>>> lwgeom_pg.h:57: warning: type defaults to 'int' in declaration of
>>>>>>>> 'BOX2DFLOAT4_ymin'
>>>>>>>> lwgeom_pg.h:57: warning: parameter names (without types) in
>>>>>>>> lwgeom_pg.h:57: warning: data definition has no type or storage
>>>>>>>> class
>>>>>>>> lwgeom_pg.h:59: error: syntax error before 'LWGEOM_force_2d'
>>>>>>>> lwgeom_pg.h:59: warning: type defaults to 'int' in declaration of
>>>>>>>> 'LWGEOM_force_2d'
>>>>>>>> lwgeom_pg.h:59: warning: parameter names (without types) in
>>>>>>>> lwgeom_pg.h:59: warning: data definition has no type or storage
>>>>>>>> class
>>>>>>>> lwgeom_pg.h:60: error: syntax error before 'LWGEOM_force_3dm'
>>>>>>>> lwgeom_pg.h:60: warning: type defaults to 'int' in declaration of
>>>>>>>> 'LWGEOM_force_3dm'
>>>>>>>> lwgeom_pg.h:60: warning: parameter names (without types) in
>>>>>>>> lwgeom_pg.h:60: warning: data definition has no type or storage
>>>>>>>> class
>>>>>>>> lwgeom_pg.h:61: error: syntax error before 'LWGEOM_force_3dz'
>>>>>>>> lwgeom_pg.h:61: warning: type defaults to 'int' in declaration of
>>>>>>>> 'LWGEOM_force_3dz'
>>>>>>>> lwgeom_pg.h:61: warning: parameter names (without types) in
>>>>>>>> lwgeom_pg.h:61: warning: data definition has no type or storage
>>>>>>>> class
>>>>>>>> lwgeom_pg.h:62: error: syntax error before 'LWGEOM_force_4d'
>>>>>>>> lwgeom_pg.h:62: warning: data definition has no type or storage
>>>>>>>> class
>>>>>>>> lwgeom_pg.h:63: error: syntax error before
>>>>>>>> 'LWGEOM_force_collection'
>>>>>>>> lwgeom_pg.h:63: warning: type defaults to 'int' in declaration of
>>>>>>>> lwgeom_pg.h:63: warning: parameter names (without types) in
>>>>>>>> lwgeom_pg.h:63: warning: data definition has no type or storage
>>>>>>>> class
>>>>>>>> lwgeom_pg.h:64: error: syntax error before 'LWGEOM_force_multi'
>>>>>>>> lwgeom_pg.h:64: warning: type defaults to 'int' in declaration of
>>>>>>>> lwgeom_pg.h:64: warning: parameter names (without types) in
>>>>>>>> lwgeom_pg.h:64: warning: data definition has no type or storage
>>>>>>>> class
>>>>>>>> lwgeom_pg.h:66: error: syntax error before 'LWGEOMFromWKB'
>>>>>>>> lwgeom_pg.h:66: warning: type defaults to 'int' in declaration of
>>>>>>>> 'LWGEOMFromWKB'
>>>>>>>> lwgeom_pg.h:66: warning: parameter names (without types) in
>>>>>>>> lwgeom_pg.h:66: warning: data definition has no type or storage
>>>>>>>> class
>>>>>>>> lwgeom_pg.h:67: error: syntax error before 'WKBFromLWGEOM'
>>>>>>>> lwgeom_pg.h:67: warning: type defaults to 'int' in declaration of
>>>>>>>> 'WKBFromLWGEOM'
>>>>>>>> lwgeom_pg.h:67: warning: parameter names (without types) in
>>>>>>>> lwgeom_pg.h:67: warning: data definition has no type or storage
>>>>>>>> class
>>>>>>>> lwgeom_pg.h:69: error: syntax error before 'LWGEOM_getBBOX'
>>>>>>>> lwgeom_pg.h:69: warning: type defaults to 'int' in declaration of
>>>>>>>> 'LWGEOM_getBBOX'
>>>>>>>> lwgeom_pg.h:69: warning: parameter names (without types) in
>>>>>>>> lwgeom_pg.h:69: warning: data definition has no type or storage
>>>>>>>> class
>>>>>>>> lwgeom_pg.h:70: error: syntax error before 'LWGEOM_addBBOX'
>>>>>>>> lwgeom_pg.h:70: warning: type defaults to 'int' in declaration of
>>>>>>>> 'LWGEOM_addBBOX'
>>>>>>>> lwgeom_pg.h:70: warning: parameter names (without types) in
>>>>>>>> lwgeom_pg.h:70: warning: data definition has no type or storage
>>>>>>>> class
>>>>>>>> lwgeom_pg.h:71: error: syntax error before 'LWGEOM_dropBBOX'
>>>>>>>> lwgeom_pg.h:71: warning: type defaults to 'int' in declaration of
>>>>>>>> 'LWGEOM_dropBBOX'
>>>>>>>> lwgeom_pg.h:71: warning: parameter names (without types) in
>>>>>>>> lwgeom_pg.h:71: warning: data definition has no type or storage
>>>>>>>> class
>>>>>>>> liblwgeom.c: In function 'trim_trailing_zeros':
>>>>>>>> liblwgeom.c:158: warning: implicit declaration of function 'strchr'
>>>>>>>> liblwgeom.c:158: warning: incompatible implicit declaration of
>>>>>>>> built-in function 'strchr'
>>>>>>>> liblwgeom.c:163: warning: implicit declaration of function 'strlen'
>>>>>>>> liblwgeom.c:163: warning: incompatible implicit declaration of
>>>>>>>> built-in function 'strlen'
>>>>>>>> make[1]: *** [liblwgeom.o] Error 1
>>>>>>>> On 1/12/06, strk at refractions.net <strk at refractions.net> wrote:
>>>>>>>>> Please show some more lines - starting right before the *first*
>>>>>>>>> warning during make - after a make clean.
>>>>>>>>> --strk;
>>>>>>>>> On Thu, Jan 12, 2006 at 08:39:25AM -0700, Assad Jarrahian wrote:
>>>>>>>>>> I am talking about the latest release 1.10
>>>>>>>>>> Yes it seems that I can find postgres.h
>>>>>>>>>> pg_config --includedir-server
>>>>>>>>>> What should I do with it?
>>>>>>>>>> thanks.
>>>>>>>>>> -assad
>>>>>>>>>>> You're talking about postgis version ?
>>>>>>>>>>> Can you find postgres.h under `/usr/bin/pg_config
>>>>>>>>>>> --includedir-server` ?
>>>>>>>>>>> --strk;
>>>>>>>>>>> On Thu, Jan 12, 2006 at 01:46:17AM -0700, Assad Jarrahian wrote:
>>>>>>>>>>>> David and all,
>>>>>>>>>>>> Thanks. I got everything installed, but when installing
>>>>>>>>>>>> postgis I
>>>>>>>>>>>> got errors (see below).
>>>>>>>>>>>> The configure summary:
>>>>>>>>>>>> SUMMARY
>>>>>>>>>>>> HOST_OS: linux-gnu
>>>>>>>>>>>> PGSQL: /usr/bin/pg_config
>>>>>>>>>>>>  GEOS: /usr/local/bin/geos-config (with C-API)
>>>>>>>>>>>>  PROJ: dir=/usr/local
>>>>>>>>>>>> ICONV: 1
>>>>>>>>>>>> PORTNAME: linux
>>>>>>>>>>>> PREFIX: /usr
>>>>>>>>>>>> EPREFIX: ${prefix}
>>>>>>>>>>>>    DOC: /usr/share/doc/postgresql-doc-8.1
>>>>>>>>>>>>   DATA: /usr/share/postgresql/8.1/postgresql/contrib
>>>>>>>>>>>>    MAN: /usr/share/postgresql/8.1/man
>>>>>>>>>>>>    BIN: /usr/lib/postgresql/8.1/bin
>>>>>>>>>>>>    EXT: /usr/lib/postgresql/8.1/lib (\$$libdir)
>>>>>>>>>>>> and the errors:
>>>>>>>>>>>> declaration of
>>>>>>>>>>>> 'getGeometryOID'
>>>>>>>>>>>> storage class
>>>>>>>>>>>> declaration of
>>>>>>>>>>>> 'box2df_to_box'
>>>>>>>>>>>> storage class
>>>>>>>>>>>> declaration of 'BOX2D_same'
>>>>>>>>>>>> storage class
>>>>>>>>>>>> declaration of
>>>>>>>>>>>> 'BOX2D_overlap'
>>>>>>>>>>>> storage class
>>>>>>>>>>>> declaration of
>>>>>>>>>>>> 'BOX2D_overleft'
>>>>>>>>>>>> storage class
>>>>>>>>>>>> declaration of 'BOX2D_left'
>>>>>>>>>>>> storage class
>>>>>>>>>>>> lwgeom_pg.h:44: error: syntax error before 'BOX2D_right'
>>>>>>>>>>>> declaration of 'BOX2D_right'
>>>>>>>>>>>> storage class
>>>>>>>>>>>> declaration of
>>>>>>>>>>>> 'BOX2D_overright'
>>>>>>>>>>>> storage class
>>>>>>>>>>>> declaration of
>>>>>>>>>>>> 'BOX2D_overbelow'
>>>>>>>>>>>> storage class
>>>>>>>>>>>> declaration of 'BOX2D_below'
>>>>>>>>>>>> storage class
>>>>>>>>>>>> declaration of 'BOX2D_above'
>>>>>>>>>>>> storage class
>>>>>>>>>>>> declaration of
>>>>>>>>>>>> 'BOX2D_overabove'
>>>>>>>>>>>> storage class
>>>>>>>>>>>> declaration of
>>>>>>>>>>>> 'BOX2D_contained'
>>>>>>>>>>>> storage class
>>>>>>>>>>>> declaration of
>>>>>>>>>>>> 'BOX2D_contain'
>>>>>>>>>>>> storage class
>>>>>>>>>>>> declaration of
>>>>>>>>>>>> 'LWGEOM_getBBOX'
>>>>>>>>>>>> storage class
>>>>>>>>>>>> declaration of
>>>>>>>>>>>> 'LWGEOM_addBBOX'
>>>>>>>>>>>> storage class
>>>>>>>>>>>> declaration of
>>>>>>>>>>>> 'LWGEOM_dropBBOX'
>>>>>>>>>>>> storage class
>>>>>>>>>>>> 'strchr'
>>>>>>>>>>>> 'strlen'
>>>>>>>>>>>> make: *** [liblwgeom] Error 2
>>>>>>>>>>>> On 1/12/06, Stefano Costa <steko at iosa.it> wrote:
>>>>>>>>>>>>> Il giorno gio, 12/01/2006 alle 00.28 -0700, Assad Jarrahian
>>>>>>>>>>>>> ha scritto:
>>>>>>>>>>>>>> hey david and all,
>>>>>>>>>>>>>> thanks for replying.
>>>>>>>>>>>>>> I tried the first step and it raised an exception
>>>>>>>>>>>>>> sudo apt-get postgresql-dev
>>>>>>>>>>>>>> E: Invalid operation postgresql-dev
>>>>>>>>>>>>> You should add an "install" just like this:
>>>>>>>>>>>>> sudo apt-get install postgresql-dev
>>>>>>>>>>>>> Regards,
>>>>>>>>>>>>> Stefano
>>>>>>>>>>>>> Stefano Costa
>>>>>>>>>>>>> http://www.iosa.it Software Open Source per l'Archeologia
>>>>>>>>>>>>> Jabber: steko at jabber.linux.it
>>>>>>>>>>>>> GnuPG Key ID 1024D/0xD0D30245
>>>>>>>>>>>>> Linux Registered User #385969 counter.li.org
>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>> postgis-users mailing list
>>>>>>>>>>>>> postgis-users at postgis.refractions.net
>>>>>>>>>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>>>>>>>>>>> /"\    ASCII Ribbon Campaign
>>>>>>>>>>> \ /    Respect for low technology.
>>>>>>>>>>> X     Keep e-mail messages readable by any computer system.
>>>>>>>>>>> / \    Keep it ASCII.
>>>>>>>>> / \    Keep it ASCII.
>>>>>> / \    Keep it ASCII.
