[postgis-users] postgis_restore.pl loads no data (pg-8.1, postgis-1.1)
Benjamin Thelen bt at ccgis.de
Tue Jan 17 07:05:48 PST 2006
Great! Thanks! That's it!
Ben
strk at refractions.net schrieb:
> Ouch!
> Those lines were left in during testing ...
> Comment them out and everything should work.
> Sorry :(
> --strk;
> On Mon, Jan 16, 2006 at 06:34:50PM -0700, Michael Fuhr wrote:
>> On Mon, Jan 16, 2006 at 01:32:38PM +0100, strk at refractions.net wrote:
>>> Still hung? What is your computed doing during the hung ?
>>> Can you show initial lines of top(1) output ?
>>> Can you show output/error of postgis_restore.pl run ?
>> I just ran some tests with PostgreSQL 8.1.2 and PostGIS 1.1.1CVS
>> on FreeBSD 6.0-STABLE and Solaris 9.  Here's what I did; both systems
>> behaved the same (skip to the bottom of this message to see what I
>> think is wrong):
>>   createdb test1
>>   createlang plpgsql test1
>>   psql -d test1 -f lwpostgis.sql
>>   psql -d test1 -f spatial_ref_sys.sql
>>   pg_dump -Fc test1 > test1.dump
>>   sh utils/postgis_restore.pl lwpostgis.sql test2 test1.dump > restore.log
>> If I now connect to test2 I see that it has no tables, not even
>> geometry_columns or spatial_ref_sys.  On line 747 of restore.log I
>> see this:
>>   Producing ascii dump test1.dump.ascii
>> and on lines 2562ff I see this:
>>   END;
>>   Sourcing lwpostgis.sql
>>   Dropping geometry_columns and spatial_ref_sys
>>   Now source test1.dump.ascii manually
>>   LANGUAGE 'plpgsql' VOLATILE STRICT; -- WITH (isstrict);
>> Something doesn't look right there -- three lines have been
>> intermingled with a CREATE OR REPLACE FUNCTION command.  The above
>> output is from the FreeBSD box; the Solaris box did the same thing
>> but the lines are intermingled elsewhere (lines 3017ff).
>> At the end of restore.log I see this:
>>   -- END
>>   COMMIT;
>>   COMMIT
>>   DROP TABLE geometry_columns;DROP TABLE spatial_ref_sys;
>>   DROP TABLE
>>   DROP TABLE
>> In the current directory is test1.dump.ascii; loading that file
>> restores the tables:
>>   psql -d test2 -f test1.dump.ascii
>> I see the following lines near the end of the 1.1 postgis_restore.pl
>> script:
>>   print "Now source $dumpascii manually\n";
>>   exit(1);
>> In 1.0 those lines are commented out.  The code that follows loads
>> the .dump.ascii file, but in 1.1 that code isn't reached because
>> of the exit(1) statement.
>> Michael Fuhr
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
