[postgis-users] line_locate_point() function
Emily Gouge
egouge at refractions.net
Thu Jan 12 13:41:07 PST 2006
Hi all,
I have a linestring and a point that I am passing to the line_locate_point() function. The point is
identical to the last coordinate of the linestring, however the line_locate_point() function is not
returning 1 as I would expect. Is this a bug or am I doing something wrong?
The query:
select line_locate_point(geomfromtext('LINESTRING(-1953743.873 471070.784,-1953735.105
471075.419,-1953720.034 471081.649)', 6269), geomfromtext('POINT(-1953720.034 471081.
649)', 6269));
line_locate_point
0.99895463120899
(1 row)
An interesting thing to note is if I remove the middle coordinate of the linestring I do get 1:
select line_locate_point(geomfromtext('LINESTRING(-1953743.873 471070.784,-1953720.034 471081.649)',
6269), geomfromtext('POINT(-1953720.034 471081.649)', 6269));
line_locate_point
1
select * from postgis_full_version();
POSTGIS="1.1.1CVS" GEOS="2.1.1" PROJ="Rel. 4.4.9, 29 Oct 2004" USE_STATS
Thanks,
Emily
