[postgis-users] Problem on ./configure
Jeff Lounsbury
jeffloun at refractions.net
Tue Jan 17 09:10:58 PST 2006
I've never had any problems just installing from source
(ftp://ftp.remotesensing.org/proj/proj-4.4.9.tar.gz), very simple:
tar –xvzf proj-4.4.9.tar.gz
cd proj-4.4.9
./configure –prefix /opt/proj-4.4.9
make
su
make install
echo /opt/proj-4.4.9/lib >> /etc/ld.so.conf
ldconfig
If you don't have a practical problem using source that is... Sorry if
this is too obvious and you've already considered this option, I thought
there was a slight chance it might help... :-)
Cheers,
-Jeff
Frank Koormann wrote:
> * Ezequias Rodrigues da Rocha <ezequias at recife.pe.gov.br> [060117 15:42]:
>>I have no project-devel package here.
>>I just download the full packages for mapserver on this website:
>>http://mappinghacks.com/rpm/fedora/4/
>>Have anybody have a suggestion ?
> Hm, there isn't any proj-* file in the directory you pointed. However, I
> can find proj-4.4.9 runtime and devel-packages under
> http://mappinghacks.com/rpm/fedora/2/
> as well as
> http://mappinghacks.com/rpm/fedora/3/
> Regards,
> Frank
