[postgis-users] Problem on ./configure
Ezequias Rodrigues da Rocha ezequias at recife.pe.gov.br
Tue Jan 17 10:41:35 PST 2006
Dear Jeff,
It is been a rally for me but I need to finish this installation as soon
as possible.
So let's go.
I installed the proj. I think it is installed properly now.
The file projects.h is in
/opt/proj-4.4.9/include
I try to configure PostGIS but it remains with the same error message:
[root at dc postgis-1.1.0]# ./configure --with-pgsql=/usr/local/pgsql/bin
--with-proj=/opt/proj-4.4.9/include
The error message is:
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking iconv.h usability... yes
checking iconv.h presence... yes
checking for iconv.h... yes
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
./configure: line 3568: /usr/local/pgsql/bin: is a directory
./configure: line 3569: /usr/local/pgsql/bin: is a directory
./configure: line 3570: /usr/local/pgsql/bin: is a directory
./configure: line 3571: /usr/local/pgsql/bin: is a directory
./configure: line 3572: /usr/local/pgsql/bin: is a directory
checking for geos-config... /usr/bin/geos-config
checking for proj... /usr/bin/proj
configure: error: Can't find proj dir.
What I did incorrectly ?
Ezequias
Jeff Lounsbury escreveu:
> I've never had any problems just installing from source
> (ftp://ftp.remotesensing.org/proj/proj-4.4.9.tar.gz), very simple:
> tar –xvzf proj-4.4.9.tar.gz
> cd proj-4.4.9
> /configure –prefix /opt/proj-4.4.9
> make
> su
> make install
> echo /opt/proj-4.4.9/lib >> /etc/ld.so.conf
> ldconfig
> If you don't have a practical problem using source that is... Sorry if
> this is too obvious and you've already considered this option, I
> thought there was a slight chance it might help... :-)
> Cheers,
> -Jeff
> Frank Koormann wrote:
>> * Ezequias Rodrigues da Rocha <ezequias at recife.pe.gov.br> [060117
>> 15:42]:
>>> I have no project-devel package here.
>>> I just download the full packages for mapserver on this website:
>>> http://mappinghacks.com/rpm/fedora/4/
>>> Have anybody have a suggestion ?
>> Hm, there isn't any proj-* file in the directory you pointed. However, I
>> can find proj-4.4.9 runtime and devel-packages under
>> http://mappinghacks.com/rpm/fedora/2/
>> as well as
>> http://mappinghacks.com/rpm/fedora/3/
>> Regards,
>>         Frank
> postgis-users mailing list
http://ezequiasrocha.blogspot.com
msn:ezequias at hotmail.com
"the worst of democracies is still better than the best of dictatorship"
