[postgis-users] Problem on ./configure
Randy James
rjames57 at yahoo.com
Tue Jan 17 10:37:50 PST 2006
Try
./configure --with-pgsql=/usr/local/pgsql/bin
--with-proj=/opt/proj-4.4.9
--- Ezequias Rodrigues da Rocha <ezequias at recife.pe.gov.br> wrote:
> Dear Jeff,
> It is been a rally for me but I need to finish this installation as
> soon
> as possible.
> So let's go.
> I installed the proj. I think it is installed properly now.
> The file projects.h is in
> /opt/proj-4.4.9/include
> I try to configure PostGIS but it remains with the same error
> message:
> [root at dc postgis-1.1.0]# ./configure
> --with-proj=/opt/proj-4.4.9/include
> The error message is:
> checking for strings.h... yes
> checking for inttypes.h... yes
> checking for stdint.h... yes
> checking for unistd.h... yes
> checking iconv.h usability... yes
> checking iconv.h presence... yes
> checking for iconv.h... yes
> checking build system type... i686-pc-linux-gnu
> checking host system type... i686-pc-linux-gnu
> ./configure: line 3568: /usr/local/pgsql/bin: is a directory
> ./configure: line 3569: /usr/local/pgsql/bin: is a directory
> ./configure: line 3570: /usr/local/pgsql/bin: is a directory
> ./configure: line 3571: /usr/local/pgsql/bin: is a directory
> ./configure: line 3572: /usr/local/pgsql/bin: is a directory
> checking for geos-config... /usr/bin/geos-config
> checking for proj... /usr/bin/proj
> configure: error: Can't find proj dir.
> What I did incorrectly ?
> Ezequias
> Jeff Lounsbury escreveu:
> > I've never had any problems just installing from source
> > (ftp://ftp.remotesensing.org/proj/proj-4.4.9.tar.gz), very
> simple:
> > tar –xvzf proj-4.4.9.tar.gz
> > cd proj-4.4.9
> > /configure –prefix /opt/proj-4.4.9
> > make
> > su
> > make install
> > echo /opt/proj-4.4.9/lib >> /etc/ld.so.conf
> > ldconfig
> > If you don't have a practical problem using source that is...
> Sorry if
> > this is too obvious and you've already considered this option, I
> > thought there was a slight chance it might help... :-)
> > Cheers,
> > -Jeff
> > Frank Koormann wrote:
> >> * Ezequias Rodrigues da Rocha <ezequias at recife.pe.gov.br>
> [060117
> >> 15:42]:
> >>> I have no project-devel package here.
> >>> I just download the full packages for mapserver on this
> website:
> >>> http://mappinghacks.com/rpm/fedora/4/
> >>> Have anybody have a suggestion ?
> >> Hm, there isn't any proj-* file in the directory you pointed.
> However, I
> >> can find proj-4.4.9 runtime and devel-packages under
> >> http://mappinghacks.com/rpm/fedora/2/
> >> as well as
> >> http://mappinghacks.com/rpm/fedora/3/
> >> Regards,
> >> Frank
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
> http://ezequiasrocha.blogspot.com
> msn:ezequias at hotmail.com
> "the worst of democracies is still better than the best of
> dictatorship"
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
