[postgis-users] Problem on ./configure
Ezequias Rodrigues da Rocha ezequias at recife.pe.gov.br
Tue Jan 17 10:57:28 PST 2006
Perfect. Thank you so much
Ezequias
Randy James escreveu:
> Try
> /configure --with-pgsql=/usr/local/pgsql/bin
> --with-proj=/opt/proj-4.4.9
> --- Ezequias Rodrigues da Rocha <ezequias at recife.pe.gov.br> wrote:
>> Dear Jeff,
>> It is been a rally for me but I need to finish this installation as
>> soon
>> as possible.
>> So let's go.
>> I installed the proj. I think it is installed properly now.
>> The file projects.h is in
>> /opt/proj-4.4.9/include
>> I try to configure PostGIS but it remains with the same error
>> message:
>> [root at dc postgis-1.1.0]# ./configure
>> --with-proj=/opt/proj-4.4.9/include
>> The error message is:
>> checking for strings.h... yes
>> checking for inttypes.h... yes
>> checking for stdint.h... yes
>> checking for unistd.h... yes
>> checking iconv.h usability... yes
>> checking iconv.h presence... yes
>> checking for iconv.h... yes
>> checking build system type... i686-pc-linux-gnu
>> checking host system type... i686-pc-linux-gnu
>> ./configure: line 3568: /usr/local/pgsql/bin: is a directory
>> ./configure: line 3569: /usr/local/pgsql/bin: is a directory
>> ./configure: line 3570: /usr/local/pgsql/bin: is a directory
>> ./configure: line 3571: /usr/local/pgsql/bin: is a directory
>> ./configure: line 3572: /usr/local/pgsql/bin: is a directory
>> checking for geos-config... /usr/bin/geos-config
>> checking for proj... /usr/bin/proj
>> configure: error: Can't find proj dir.
>> What I did incorrectly ?
>> Ezequias
>> Jeff Lounsbury escreveu:
>>> I've never had any problems just installing from source
>>> (ftp://ftp.remotesensing.org/proj/proj-4.4.9.tar.gz), very
>> simple:
>>> tar –xvzf proj-4.4.9.tar.gz
>>> cd proj-4.4.9
>>> /configure –prefix /opt/proj-4.4.9
>>> make
>>> su
>>> make install
>>> echo /opt/proj-4.4.9/lib >> /etc/ld.so.conf
>>> ldconfig
>>> If you don't have a practical problem using source that is...
>> Sorry if
>>> this is too obvious and you've already considered this option, I
>>> thought there was a slight chance it might help... :-)
>>> Cheers,
>>> -Jeff
>>> Frank Koormann wrote:
>>>> * Ezequias Rodrigues da Rocha <ezequias at recife.pe.gov.br>
>> [060117
>>>> 15:42]:
>>>>> I have no project-devel package here.
>>>>> I just download the full packages for mapserver on this
>> website:
>>>>> http://mappinghacks.com/rpm/fedora/4/
>>>>> Have anybody have a suggestion ?
>>>> Hm, there isn't any proj-* file in the directory you pointed.
>> However, I
>>>> can find proj-4.4.9 runtime and devel-packages under
>>>> http://mappinghacks.com/rpm/fedora/2/
>>>> as well as
>>>> http://mappinghacks.com/rpm/fedora/3/
>>>> Regards,
>>>>         Frank
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> http://ezequiasrocha.blogspot.com
>> msn:ezequias at hotmail.com
>> "the worst of democracies is still better than the best of
>> dictatorship"
> __________________________________________________
> Do You Yahoo!?
> Tired of spam?  Yahoo! Mail has the best spam protection around
> http://mail.yahoo.com
"the worst of democracies is still better than the best of dictatorship"
