[postgis-users] Geomunion problems
palmerj at xtra.co.nz
Tue Jan 17 21:37:54 PST 2006
I'm trying to complete a few polygon dissolves and geos is throwing a couple of error messages under 2 different queries. The first query is a simple union of polygons which are spatially very close to each other.
When I complete the following command:
"SELECT geomunion(shape) FROM mesh_block"
I get the following error msg:
NOTICE: TopologyException: Directed Edge visited twice during ring-building at (9.16511,-44.6877)
ERROR: GEOS union() threw an error!
I have attached a file with the geometries and table definition if that helps.
I'm also running geomunion on a different larger dataset and Im getting another problem:
SELECT sa.id,
sa.name,
sa.code,
geomunion(mb.shape) as shape
FROM crs_mesh_blk mb,
crs_mesh_blk_area mba,
crs_statist_area sa
WHERE mb.id = mba.mbk_id
AND mba.stt_id = sa.id
AND sa.sav_area_class = 'TA'
GROUP BY sa.id, sa.name, sa.code;
NOTICE: TopologyException: no outgoing dirEdge found (9.18236,-44.6848)
I have not attached this data for testing, as it quite large :(
Note I have completed isvalid tests on all of the geometries in both dataset and everything returns true.
My version of postgis is:
SELECT postgis_full_version();
POSTGIS="1.0.4" GEOS="2.1.4" PROJ="Rel. 4.4.9, 29 Oct 2004" USE_STATS DBPROC="0.3.0" RELPROC="0.3.0"
Any help on these errors and how to resolve them would be greatly appreciated.
Cheers
Jeremy Palmer
Type: application/x-zip-compressed
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060118/68177e2d/attachment.bin>
