[postgis-users] Problem on ./configure
Mark Cave-Ayland
m.cave-ayland at webbased.co.uk
Wed Jan 18 04:16:47 PST 2006
> From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Ezequias
Rodrigues da Rocha
> Sent: 18 January 2006 12:10
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] Problem on ./configure
>Please see my strange result (on ./configure and on make) and tell me why
the root has permission denied.
> [root at dc postgis-1.1.0]# ./configure --with-pgsql=/usr/local/pgsql/bin
--with-proj=/opt/proj-4.4.9/
Hi Ezequias,
As strk pointed out, the --with-pgsql configure option needs to point to the
pg_config file itself, e.g. try
./configure --with-pgsql=/usr/local/pgsql/bin/pg_config
Kind regards,
Mark.
WebBased Ltd
17 Research Way
Plymouth
PL6 8BT
T: +44 (0)1752 797131
F: +44 (0)1752 791023
http://www.webbased.co.uk
http://www.infomapper.com
http://www.swtc.co.uk
This email and any attachments are confidential to the intended recipient
and may also be privileged. If you are not the intended recipient please
delete it from your system and notify the sender. You should not copy it or
use it for any purpose nor disclose or distribute its contents to any other
person.
