[postgis-users] Using more than 10 digits with pgsql2shp
Stephen Woodbridge woodbri at swoodbridge.com
Wed Jan 18 19:37:08 PST 2006
TECHER David wrote:
> Hi
> I would like to know it it could be possible in a next pgsql2shp's version
> to use more than the limitation from 10 digits for each field?
Hi David,
This limitation is not with pgsql2shp, but with the *.dbf file design
spec which limits the fieldnames to 10 characters. So unless ESRI
changes the design of the shapefile spec there is nothing that can be
done by the PostGIS team.
-Steve W.
