[postgis-users] HTML output
Kevin Neufeld kneufeld at refractions.net
Tue Jan 24 08:25:19 PST 2006
Yes, this is true... but it's PostgreSQL, the database, that has this
option, not PostGIS, a plugin to PostgreSQL that spatially enables the
database - that is, allows you to store geometry objects.
See (http://www.postgresql.org/docs/8.1/static/app-psql.html) - In
particular, the \H and \pset options from psql, PostgreSQL's
command-line client application.
Basically, after typing \H and setting the appropriate variables with
\pset, all output is wrapped with html tags. Or use the -H option when
launching psql. You could also use the -c option to send a query to the
database and pipe the results to a file or wherever you choose. After
that, it's up to your creativity to do something useful with the results :)
Cheers,
Kevin
Ezequias Rodrigues da Rocha wrote:
> Hi list,
> I just receive a message that PostGIS does have a function that send
> an output in html format. Is it true ? Could someone tell me how this
> process occurs ?
> Sincerely...
Kevin Neufeld,
Refractions Research Inc.,
Phone: (250) 383-3022
Fax:   (250) 383-2140
