[postgis-users] HTML output
Ezequias Rodrigues da Rocha
ezequias at recife.pe.gov.br
Wed Jan 25 04:40:00 PST 2006
Nice,
Do you know if it is possible by using jdbc ?
Sincerely
Ezequias
Kevin Neufeld escreveu:
> Yes, this is true... but it's PostgreSQL, the database, that has this
> option, not PostGIS, a plugin to PostgreSQL that spatially enables the
> database - that is, allows you to store geometry objects.
> See (http://www.postgresql.org/docs/8.1/static/app-psql.html) - In
> particular, the \H and \pset options from psql, PostgreSQL's
> command-line client application.
> Basically, after typing \H and setting the appropriate variables with
> \pset, all output is wrapped with html tags. Or use the -H option when
> launching psql. You could also use the -c option to send a query to
> the database and pipe the results to a file or wherever you choose.
> After that, it's up to your creativity to do something useful with the
> results :)
> Cheers,
> Kevin
> Ezequias Rodrigues da Rocha wrote:
>> Hi list,
>> I just receive a message that PostGIS does have a function that send
>> an output in html format. Is it true ? Could someone tell me how this
>> process occurs ?
>> Sincerely...
http://ezequiasrocha.blogspot.com
msn:ezequias at hotmail.com
"the worst of democracies is still better than the best of dictatorship"
