[postgis-users] unit
Gilbert, Antoine
AGilbert at korem.com
Tue Jan 24 05:06:11 PST 2006
I don't know why, but some projection string don't have any unit
specified..
For example
+proj=longlat +ellps=clrk66 +datum=NAD27 +no_defs
-----Original Message-----
From: David Bitner [mailto:osgis.lists at gmail.com]
Sent: January 23, 2006 5:16 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] unit
Select * from spatial_ref_sys where srid=[your srid]
Incidently, I forgot about the srid(geometry) function to get the srid
of a geometry. Put them together:
select * from spatial_ref_sys where srid=(select srid([geometry]) from
[table] limit 1)
On 1/23/06, Gilbert, Antoine <AGilbert at korem.com> wrote:
> I know the SRID
> I was figuring given the SRID I could know the unit. I don't know what
> reference system is used at each time. I only have a bunch of queries
> with srid associated
> Sent: January 23, 2006 4:46 PM
> If you don't know the projection units, then you don't know anything
> about how to reference them at all!
> If you are just using PostGIS tables set up by someone else, in
> PostGIS, you can look at a a geometry using astext(geom) this will
> give you the srid for the given projection. You can then look up that
> srid to see what projection is and what the units are. If the
> SRID=-1, then you know nothing about the projection and any distance
> that you are measuring is pretty much meaningless.
> > I wonder if there is a better way to achieve this, suppose you don't
> > know the projection of a given geometry
> > Sent: January 23, 2006 3:53 PM
> > The units that are returned are the units that the projection your
> > data is in. For example, if your data is in meters then the
distance
> > returned will be in meters to get your distance in kilometers, you
> > could use this query Distance(geometry,geometry)/1000.
> > > Hi
> > > When you are using functions like Distance(geometry, geometry),
> > withinh SQL
> > > queries, does it exists an easy way to tell the system I want
> > kilometer
> > > units ?
> > > Antoine
> > > _______________________________________________
> > > postgis-users mailing list
> > > postgis-users at postgis.refractions.net
> > > http://postgis.refractions.net/mailman/listinfo/postgis-users
