[postgis-users] strange jdbc problem
Gilbert, Antoine AGilbert at korem.com
Thu Jan 26 05:39:34 PST 2006
I have worked with a lot of JDBC drivers, and it's the first one with
this default behavior.
-----Original Message-----
From: Guido Lemoine [mailto:guido.lemoine at jrc.it]
Sent: January 26, 2006 3:08 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] strange jdbc problem
If you do such a select as a normal query (in postgresql) you would also
get the whole 500,000 record set. Its display would prob. take some 10
seconds as well (the 19 s in jdbc are the overhead in loading the set in
a
rowset object). The fetchsize in jdbc works, more or less, equivalent
to a "limit" in an sql query.
So, the default behavior is exactly as expected. Maybe it is strange to
load 500,000 records in a Java application.
GL
Gilbert, Antoine wrote:
>A guy pointed me on how to resolve this kind of problem
>Here are the explanations
>"By default the JDBC driver will fetch the entire ResultSet before the
>executeQuery call returns.  If you don't want this behavior set the
>fetchsize appropriately."
>http://jdbc.postgresql.org/documentation/81/query.html#query-with-curso
r
>All is ok now. It's a very strange default behavior in my own
>opinion....
>From: Paul Ramsey [mailto:pramsey at refractions.net]
>Sent: January 25, 2006 4:22 PM
>Antoine,
>You need to use a forwardonly cursor if you want a fast return.
>Otherwise the JDBC system is pulling the whole resultset into the
>client side, for your use.  This is a general postgresql jdbc issue,
>not a postgis issue, check the jdbc documentation on the postgresql
>site.
>P.
>On Jan 25, 2006, at 11:50 AM, Gilbert, Antoine wrote:
>>Hi
>>I have a single PostGIS table in PostgreSQL
>>This table have like 500000 records
>>I use the JDBC driver to only send a quick query without browsing
>>resultset and it take forever. For example:
>>Statement stmt = connection.createStatement();
>>ResultSet rs =stmt.executeQuery("select street from \"QCs_polyline
>>stmt.close();
>>This takes 19 sec. Does I am missing something like a configuration
>>on the driver? So far I was just testing PostGIS/PostgreSQL with
>>tiny tables.
>>_______________________________________________
>>postgis-users mailing list
>>postgis-users at postgis.refractions.net
>>http://postgis.refractions.net/mailman/listinfo/postgis-users
