[postgis-users] snapToGrid strange behaviour
    Kevin Neufeld
    kneufeld at refractions.net
    Thu Jan 26 14:25:58 PST 2006
Can somebody please explain why we are getting these results?
test=# select snaptogrid(the_geom, 0.001) ~= the_geom from tmp1;
 ?column?
 f
(1 row)
test=# update tmp1 set the_geom = snaptogrid(the_geom, 0.001);
UPDATE 1
 ?column?
 f
(1 row)
OR
test=# SELECT a.geom,
test-#        b.geom,
test-#        asText(a.geom),
test-#        asText(b.geom),
test-#        equals(a.geom, b.geom),
test-#        a.geom ~= b.geom
test-# FROM (SELECT snapToGrid('POINT(1.23456789 9.87654321)'::geometry,
0.001) AS geom) AS a,
test-#      (SELECT snapToGrid(snapToGrid('POINT(1.23456789
9.87654321)'::geometry, 0.001), 0.00001) AS geom) AS b;
-[ RECORD 1 ]----------------------------------------
geom     | 0101000000C3F5285C8FC2F33F1B2FDD2406C12340
astext   | POINT(1.235 9.877)
equals   | t
?column? | t
test-#        b.geom,
9.87654321)'::geometry, 0.001), 0.000001) AS geom) AS b;
geom     | 0101000000C2F5285C8FC2F33F1A2FDD2406C12340
equals   | f
?column? | f
Cheers,
Kevin
Kevin Neufeld,
Refractions Research Inc.,
Phone: (250) 383-3022
Fax:   (250) 383-2140
