[postgis-users] snapToGrid strange behaviour
Kevin Neufeld
kneufeld at refractions.net
Fri Jan 27 11:04:06 PST 2006
Hmmm. That's interesting. Thanx for your input Michael. For some reason,
I assumed the snapToGrid(...) function simply rounded off geometry
points at a specified precision by using a simple "floor(point /
precision + 0.5) * precision" algorithm. Unfortunately, this means for
me that I can't rely on spatial queries performed on snapped geometries,
ie. touching geometries snapped to 0.001 may actually be 0.00000001
apart and consequently, not spatially touching. I'll have to investigate
this further.
Thanx again for you help Michael,
Cheers,
Kevin
Michael Fuhr wrote:
>On Fri, Jan 27, 2006 at 08:09:37AM -0800, Kevin Neufeld wrote:
>>That's exactly what I was thinking as well. But the question remains,
>>why does snapToGrid(...) not actually snap to 0.001 as instructed?
>Presumably it does, but wee differences are probably creeping in
>because 0.001 and the resulting values don't have exact binary
>representations. Those errors are smaller than the double precision
>type's stated accuracy (15 decimal digits or so), but they make the
>values different when doing bit-for-bit equality tests. So if the
>"same" value is arrived at by different calculations, the binary
>representations might be different. Example:
>test=> CREATE TABLE foo (d1 float8, d2 float8, d3 float8, d4 float8, d5 float8);
>test=> INSERT INTO foo VALUES (1.0, 1000.0, 999.0);
>test=> UPDATE foo SET d4 = d1 / d2, d5 = d1 - d3 / d2;
>test=> SELECT d4, d5, d4 = d5 FROM foo;
> d4 | d5 | ?column?
> 0.001 | 0.001 | f
>(1 row)
>test=> SELECT encode(float8send(d4), 'hex'), encode(float8send(d5), 'hex')
>test-> FROM foo;
> encode | encode
> 3f50624dd2f1a9fc | 3f50624dd2f1aa00
>(1 row)
Kevin Neufeld,
Refractions Research Inc.,
Phone: (250) 383-3022
Fax: (250) 383-2140
