[postgis-users] snapToGrid strange behaviour
Michael Fuhr
mike at fuhr.org
Fri Jan 27 14:09:40 PST 2006
On Fri, Jan 27, 2006 at 11:04:06AM -0800, Kevin Neufeld wrote:
> Hmmm. That's interesting. Thanx for your input Michael. For some reason,
> I assumed the snapToGrid(...) function simply rounded off geometry
> points at a specified precision by using a simple "floor(point /
> precision + 0.5) * precision" algorithm. Unfortunately, this means for
> me that I can't rely on spatial queries performed on snapped geometries,
> ie. touching geometries snapped to 0.001 may actually be 0.00000001
> apart and consequently, not spatially touching. I'll have to investigate
> this further.
The difference is likely to be much smaller than 0.00000001; as I
mentioned, it'll probably be smaller than a double's stated accuracy
of about 15 decimal digits. Here's another query from the example
in my last post:
test=> SELECT d4, d5, d4 = d5, d5 - d4 FROM foo;
d4 | d5 | ?column? | ?column?
0.001 | 0.001 | f | 8.67361737988404e-19
(1 row)
I was thinking about raising the issue of tolerances in comparisons,
as Martin did. Programmers who work with floating point have learned
to do things like "if (fabs(x - y) < tolerance)" instead of testing
for equality; it might be convenient if geometry functions that test
for equality had a way to specify a tolerance.
Michael Fuhr
