[postgis-users] vers 1.1.1 configure fails on Ubuntu
Mike Leahy
mgleahy at alumni.uwaterloo.ca
Fri Jan 27 17:14:55 PST 2006
John,
Did you add a parameter to ./configure that points to the actual
pg_config file? I just compiled PostGIS on FC4 with the following options:
./configure --prefix=/usr --with-pgsql=/usr/bin/pg_config \
--with-geos=/usr/bin/geos-config --with-proj=/usr
It compiled and installed fine for me...if you want more info about
these options, you can usually enter './configure --help' to see a list.
Mike
John Taber wrote:
> My ./configure fails on Ubuntu Breezy saying Postgresql must be
> installed which it is - version 8.0. Perhaps it is looking for some
> hard path that is different on Breezy. Any suggestions?
> postgis-users mailing list
