[postgis-users] addgeometry not found
John Taber
jtaber at johntaber.net
Sun Jan 29 11:39:40 PST 2006
It appeared that postgis compiled without errors and make installed
correctly but I'm getting the following errors. Running postgis 1.1.1
and postgres 8.0 on ubuntu. Any ideas:
> shp2pgsql -D Water.shp water testshape | psql testshape
> Shapefile type: Arc
> Postgis type: MULTILINESTRING[2]
> BEGIN
> NOTICE: CREATE TABLE will create implicit sequence "water_gid_seq" for serial column "water.gid"
> NOTICE: CREATE TABLE / PRIMARY KEY will create implicit index "water_pkey" for table "water"
> CREATE TABLE
> ERROR: function addgeometrycolumn("unknown", "unknown", "unknown", "unknown", "unknown", integer) does not exist
> HINT: No function matches the given name and argument types. You may need to add explicit type casts.
> ERROR: current transaction is aborted, commands ignored until end of transaction block
