[postgis-users] JAVA and post GIS
Emily Gouge egouge at refractions.net
Mon Jan 30 08:26:16 PST 2006
There is some documentation and an example on connecting to PostGIS using Java.  See:
http://postgis.refractions.net/docs/ch04.html#id2789526
You can add a datatype to the postgres connection and then the getObject() call will return a
PGGeometry object:
((org.postgresql.Connection)conn).addDataType("geometry","org.postgis.PGgeometry");
Additionally you can also check out the postgis_jts jar, which provides the ability to return a
JtsGeometry object (and subsequently to convert this object to a JTS Geometry object).
Emily
Fatemeh Abbasinejad wrote:
> I am new to PostGIS. Does anyone know how we can retrieve our defined data types
> (like point,circle,...) from a ResultSet in java. I used getObject but it didn't work.
>   -fatemeh
> Bring words and photos together (easily) with
>  PhotoMail  - it's free and works with Yahoo! Mail.
> postgis-users mailing list
