[postgis-users] encoding question
Gustavo Henrique Sberze Ribas
gribas at cpqd.com.br
Mon Jan 30 09:42:30 PST 2006
Hello,
SQL_ASCII is for 7-bit text data only, if you need to store text in
French use LATIN1 instead (or UNICODE).
With SQL_ASCII there is no restriction on what data can be entered
and you can get yourself in a real mess with different clients entering
data in different encodings.
Java has no clue about how to translate back the extended characters.
What charSet will it use? What was the original encoding? Of course, you
can force the use of a particular encoding against a stream of bytes and
keep your database in SQL_ASCII but I strongly advise against it.
regards,
Gustavo
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net]On Behalf Of Gilbert, Antoine
Sent: Monday, January 30, 2006 2:59 PM
To: PostGIS Users Discussion
Subject: [postgis-users] encoding question
Hi
I have a postgresql database, the encoding of the database is SQL_ASCII
When I use the postgresql driver, I have problem retrieving special characters that
display correctly in the postgres admin.
Any idea ?
Antoine
