[postgis-users] encoding question
Gilbert, Antoine
AGilbert at korem.com
Mon Jan 30 09:50:55 PST 2006
But why in the postgresql admin it show accent correctly ?
-----Original Message-----
From: Gustavo Henrique Sberze Ribas [mailto:gribas at cpqd.com.br]
Sent: January 30, 2006 12:43 PM
To: PostGIS Users Discussion
Subject: RE: [postgis-users] encoding question
Hello,
SQL_ASCII is for 7-bit text data only, if you need to store text in
French use LATIN1 instead (or UNICODE).
With SQL_ASCII there is no restriction on what data can be entered
and you can get yourself in a real mess with different clients entering
data in different encodings.
Java has no clue about how to translate back the extended characters.
What charSet will it use? What was the original encoding? Of course, you
can force the use of a particular encoding against a stream of bytes and
keep your database in SQL_ASCII but I strongly advise against it.
regards,
Gustavo
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net]On Behalf Of
Gilbert, Antoine
Sent: Monday, January 30, 2006 2:59 PM
Subject: [postgis-users] encoding question
Hi
I have a postgresql database, the encoding of the database is SQL_ASCII
When I use the postgresql driver, I have problem retrieving special
characters that
display correctly in the postgres admin.
Any idea ?
Antoine
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
