[postgis-users] encoding question
Gustavo Henrique Sberze Ribas gribas at cpqd.com.br
Mon Jan 30 10:30:36 PST 2006
> But why in the postgresql admin it show accent correctly ?
  It probably uses the default OS encoding, which luckily is the same
encoding used to store the bytes. :) Try entering some text in Cyrillic
or Japanese and you'll see the mess you're heading to. ;)
regards,
Gustavo
> -----Original Message-----
> From: Gustavo Henrique Sberze Ribas [mailto:gribas at cpqd.com.br]
> Sent: January 30, 2006 12:43 PM
> To: PostGIS Users Discussion
> Subject: RE: [postgis-users] encoding question
> Hello,
>   SQL_ASCII is for 7-bit text data only, if you need to store text in
> French use LATIN1 instead (or UNICODE).
>   With SQL_ASCII there is no restriction on what data can be entered
> and you can get yourself in a real mess with different
> clients entering
> data in different encodings.
>   Java has no clue about how to translate back the extended
> characters.
> What charSet will it use? What was the original encoding? Of
> course, you
> can force the use of a particular encoding against a stream
> of bytes and
> keep your database in SQL_ASCII but I strongly advise against it.
> regards,
> Gustavo
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net]On Behalf Of
> Gilbert, Antoine
> Sent: Monday, January 30, 2006 2:59 PM
> Subject: [postgis-users] encoding question
> Hi
> I have a postgresql database, the encoding of the database is
> SQL_ASCII
> When I use the postgresql driver, I have problem retrieving special
> characters that
> display correctly in the postgres admin.
> Any idea ?
> Antoine
> postgis-users mailing list
