[postgis-users] JAVA and post GIS
Fatemeh Abbasinejad
fabbasinejad at yahoo.com
Mon Jan 30 12:18:31 PST 2006
Hi
I tried what you did but the program wouln't even compile. I have a table named "land" which has an attribute"geometry" of type "circle". I want to retrieve the center of the circle which is of type "point" as defined by postGIS.Here is my Program
import java.sql.*;
import org.postgis.*;
public class JavaGIS3 {
public static void main(String[] args)
java.sql.Connection conn;
try
Class.forName("org.postgresql.Driver");
String url = "jdbc:postgresql://localhost:5432/dcmms";
conn = DriverManager.getConnection(url, "postgres", "abcde");
Statement s = conn.createStatement();
ResultSet rs = s.executeQuery("select (center(geometry))as mycenter from land");
ResultSetMetaData rsmd = rs.getMetaData();
for(int i=0;rs.next();i++){
Geometry geometry = new BinaryParser().parse(rs.getBytes(1));
if(geometry.getType()==geometry.POINT){
System.out.println("Finally retrieved geometry object!")
s.close();
conn.close();
catch( Exception e )
e.printStackTrace();
I did what you had said in your email but it would give an error:
BinaryParser cannot be resolved to a type
What should I do? Did you compile your program?
"Gilbert, Antoine" <AGilbert at korem.com> wrote:
Hi
Here is my example using postgis_1_0_0.jar
Connection connection = TestUtils.getTestConnection();
Statement stmt = connection.createStatement();
ResultSet rs = stmt.executeQuery("select AsBinary(geom) as geom from \"rue_test_polyline\"");
if(geometry.getType()==geometry.MULTILINESTRING){
MultiLineString multiline = ((MultiLineString)geometry);
System.out.println(multiline.toString());
System.out.println("ligne "+i+" contient "+multiline.numLines()+" segment(s)");
for(int j=0;j<multiline.numLines();j++)
System.out.println(" segment "+j+":"+multiline.getLine(j).numPoints()+" points");
stmt.close();
connection.close();
From: Fatemeh Abbasinejad [mailto:fabbasinejad at yahoo.com]
Sent: January 30, 2006 3:43 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] JAVA and post GIS
I am new to PostGIS. Does anyone know how we can retrieve our defined data types
(like point,circle,...) from a ResultSet in java. I used getObject but it didn't work.
-fatemeh
Bring words and photos together (easily) with
PhotoMail - it's free and works with Yahoo! Mail.
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
Yahoo! Autos. Looking for a sweet ride? Get pricing, reviews, & more on new and used cars.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060130/b4aebc9d/attachment.html>
