[postgis-users] JAVA and post GIS
Gilbert, Antoine AGilbert at korem.com
Mon Jan 30 12:28:18 PST 2006
Yes
I'm not a postgis expert, but I think in your case it should be
ResultSet rs = s.executeQuery("select (AsBinary(center(geometry)))) as
mycenter from land");
You have to convert the geometry in the binary format
You can use AsText too and use new PGgeometry(rs.getString(1)) or
something like that I think
I'm using postgis_1_0_0.jar
  _____
From: Fatemeh Abbasinejad [mailto:fabbasinejad at yahoo.com]
Sent: January 30, 2006 3:19 PM
To: PostGIS Users Discussion
Subject: RE: [postgis-users] JAVA and post GIS
Hi
 I tried what you did but the program wouln't even compile. I have a
table named "land" which has an attribute"geometry" of type "circle". I
want to retrieve the center of the circle which is of type "point" as
defined by postGIS.Here is my Program
import java.sql.*;
import org.postgis.*;
public class JavaGIS3 {
  public static void main(String[] args)
    java.sql.Connection conn;
    try
      Class.forName("org.postgresql.Driver");
      String url = "jdbc:postgresql://localhost:5432/dcmms";
      conn = DriverManager.getConnection(url, "postgres", "abcde");
      Statement s = conn.createStatement();
      ResultSet rs = s.executeQuery("select (center(geometry))as
      ResultSetMetaData rsmd = rs.getMetaData();
      for(int i=0;rs.next();i++){
       Geometry geometry = new BinaryParser().parse(rs.getBytes(1));
          if(geometry.getType()==geometry.POINT){
           System.out.println("Finally retrieved geometry object!")
      s.close();
      conn.close();
    catch( Exception e )
      e.printStackTrace();
I did what you had said in your email but it would give an error:
BinaryParser cannot be resolved to a type
What should I do? Did you compile your program?
"Gilbert, Antoine" <AGilbert at korem.com> wrote:
	Hi
	Here is my example using postgis_1_0_0.jar
	Connection connection = TestUtils.getTestConnection();
	        Statement stmt = connection.createStatement();
	        ResultSet rs = stmt.executeQuery("select AsBinary(geom)
as geom from \"rue_test_polyline\"");
	            if(geometry.getType()==geometry.MULTILINESTRING){
	                MultiLineString multiline =
((MultiLineString)geometry);
	                System.out.println(multiline.toString());
	                System.out.println("ligne "+i+" contient
"+multiline.numLines()+" segment(s)");
	                for(int j=0;j<multiline.numLines();j++)
	                    System.out.println("    segment
"+j+":"+multiline.getLine(j).numPoints()+" points");
	        stmt.close();
	        connection.close();
  _____
	Sent: January 30, 2006 3:43 AM
	To: postgis-users at postgis.refractions.net
	Subject: [postgis-users] JAVA and post GIS
	I am new to PostGIS. Does anyone know how we can retrieve our
defined data types
	(like point,circle,...) from a ResultSet in java. I used
getObject but it didn't work.
	-fatemeh
  _____
	Bring words and photos together (easily) with
	PhotoMail
<http://us.rd.yahoo.com/mail_us/taglines/PMHM3/*http:/photomail.mail.yah
oo.com> - it's free and works with Yahoo! Mail.
	postgis-users mailing list
	http://postgis.refractions.net/mailman/listinfo/postgis-users
  _____
Yahoo! Autos
<http://us.rd.yahoo.com/evt=38381/%20ylc=X3oDMTEzcGlrdGY5BF9TAzk3MTA3MDc
2BHNlYwNtYWlsdGFncwRzbGsDMWF1dG9z/*http:/autos.yahoo.com/index.html%20>
. Looking for a sweet ride? Get pricing, reviews, & more on new and used
cars.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060130/5a70fab1/attachment.html>
