[postgis-users] JAVA and post GIS
Gilbert, Antoine
AGilbert at korem.com
Mon Jan 30 13:59:48 PST 2006
I don't know the center() function, but you can try the centroid() one
This query was working for me (my spatial column is geom)
select AsBinary(centroid(geom)) as mycenter from "fr_lamb_mg_1_region"
_____
From: Fatemeh Abbasinejad [mailto:fabbasinejad at yahoo.com]
Sent: January 30, 2006 4:48 PM
To: PostGIS Users Discussion
Subject: RE: [postgis-users] JAVA and post GIS
AsBinary() and AsText() require a "geometry object as input. My object
is of type "Point" and will non execute the query.I tried executing the
query alone.Am I doing something wrong? Do you know how I can convert
Point or types "circle" into binary?
I am also using postgis_1.1.0.jar.
"Gilbert, Antoine" <AGilbert at korem.com> wrote:
Yes
I'm not a postgis expert, but I think in your case it should be
ResultSet rs = s.executeQuery("select
(AsBinary(center(geometry)))) as mycenter from land");
You have to convert the geometry in the binary format
You can use AsText too and use new PGgeometry(rs.getString(1))
or something like that I think
I'm using postgis_1_0_0.jar
_____
Sent: January 30, 2006 3:19 PM
Hi
I tried what you did but the program wouln't even compile. I
have a table named "land" which has an attribute"geometry" of type
"circle". I want to retrieve the center of the circle which is of type
"point" as defined by postGIS.Here is my Program
import java.sql.*;
import org.postgis.*;
public class JavaGIS3 {
public static void main(String[] args)
java.sql.Connection conn;
try
Class.forName("org.postgresql.Driver");
String url = "jdbc:postgresql://localhost:5432/dcmms";
conn = DriverManager.getConnection(url, "postgres",
"abcde");
Statement s = conn.createStatement();
ResultSet rs = s.executeQuery("select (center(geometry))as
ResultSetMetaData rsmd = rs.getMetaData();
for(int i=0;rs.next();i++){
Geometry geometry = new
BinaryParser().parse(rs.getBytes(1));
if(geometry.getType()==geometry.POINT){
System.out.println("Finally retrieved geometry
object!")
s.close();
conn.close();
catch( Exception e )
e.printStackTrace();
I did what you had said in your email but it would give an
error:
BinaryParser cannot be resolved to a type
What should I do? Did you compile your program?
Hi
Here is my example using postgis_1_0_0.jar
Connection connection = TestUtils.getTestConnection();
Statement stmt = connection.createStatement();
ResultSet rs = stmt.executeQuery("select
AsBinary(geom) as geom from \"rue_test_polyline\"");
if(geometry.getType()==geometry.MULTILINESTRING){
MultiLineString multiline =
((MultiLineString)geometry);
System.out.println(multiline.toString());
System.out.println("ligne "+i+" contient
"+multiline.numLines()+" segment(s)");
for(int j=0;j<multiline.numLines();j++)
System.out.println(" segment
"+j+":"+multiline.getLine(j).numPoints()+" points");
stmt.close();
connection.close();
_____
Sent: January 30, 2006 3:43 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] JAVA and post GIS
I am new to PostGIS. Does anyone know how we can
retrieve our defined data types
(like point,circle,...) from a ResultSet in java. I used
getObject but it didn't work.
-fatemeh
_____
Bring words and photos together (easily) with
PhotoMail
<http://us.rd.yahoo.com/mail_us/taglines/PMHM3/*http:/photomail.mail.yah
oo.com> - it's free and works with Yahoo! Mail.
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
_____
Yahoo! Autos
<http://us.rd.yahoo.com/evt=38381/%20ylc=X3oDMTEzcGlrdGY5BF9TAzk3MTA3MDc
2BHNlYwNtYWlsdGFncwRzbGsDMWF1dG9z/*http:/autos.yahoo.com/index.html%20>
. Looking for a sweet ride? Get pricing, reviews, & more on new and used
cars.
_____
Yahoo! Autos
cars.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060130/0be5584f/attachment.html>
