[postgis-users] Compatibility with PostgreSQL 8.1.2
Frank Koormann frank.koormann at intevation.de
Mon Jan 30 21:33:10 PST 2006
Bert,
* Bert Hinrichs <a.hinrichs1 at comcast.net> [060131 05:32]:
>    I successfully download, installed, and set up PostgreSQL 8.1.2 for Fedora
>    Core 4 from rpms.
>    I attempted to use the PosgGIS 1.1.0 rpms.  It did a sort of half-a$$ed
>    install (read that somethings installed and some didn't),
To improve the packages it would be helpful to know where the packages
are from and what problems you actually encountered.
>    Everything I've read keeps coming back to build from the source, but to do
>    that, it appears that you cannot have installed PostgreSQL from a binary
>    rpm.  It seems that you have to have built PostgreSQL from a source rpm
>    because it appears that I have to unpack the tarball into a contrib source
>    tree.
>    Is this true?
No. Since PostGIS 1.1.0 you only need the PostgreSQL development
packages and can run configure with the
--with-pgsql=<FULL PATH to pg_config>
HTH
        Frank
Frank Koormann                             <frank.koormann at intevation.de>
 Professional Service around Free Software       (http://intevation.net/)
 FreeGIS Project                                 (http://freegis.org/)
