[postgis-users] PostGIS, 64 bit Solaris, Invalide memory alloc message using force_collection
strk at refractions.net
Tue Jan 31 02:52:04 PST 2006
If this is with 1.1.1 please file a bug report, so I will
have a reminder. Thank you.
--strk;
On Mon, Jan 30, 2006 at 01:52:36PM -0700, Erik Persson wrote:
> Hi all,
> I am wondering if anyone has experience running PostGIS on a 64 bit
> version of Solaris running on the Sparc architecture. The error
> described below occurred when compiled as 64 bit. A quick test on a
> 32 bit Sparc machine indicates that the problem does not exist there.
> I recently installed postgis on a solaris machine and a mapserver
> query to postgis that has been working fine on OS X and linux
> suddenly failed with an 'invalid memory alloc' error. I have reduced
> the error down to a the force_collection function. I have down-reved
> to PostgreSQL 8.1.1 and postgis 1.1.0 and experience the same problem.
> If I make a simple table with a single point column force collection
> works fine. If I add a second row I get a huge amount of output
> (with the memory alloc error appearing sporadically), about 45MB of
> data for a 2 points of dim 2 in a single column in a table with two
> rows! I have done the test with POINTS of dim 2 and 3 with similar
> results. The requested memory size appears to be the same, but at
> the moment I can't confirm that %100.
> If I use the LIMIT directive, I seem to get the error regardless of
> the number of rows, but given the sporadic nature of the problem with
> two rows of data in the table I can't be 100% of the
> reproducibility. If I select a single row using an id column it
> works fine.
> As you can see below, it is a 64 bit architecture compiled as 64
> bit. All the relevant versions and system information should be
> contained below.
> Any suggestions? Known bugs? Known problems on 64 bit architectures,
> particularly Solaris? I am happy to instrument code, try patches,
> or do other debugging.
> Thanks,
> Erik
> Example of failure:
> pod=# select force_collection(the_point) from foo;
> ERROR: invalid memory alloc request size 1073741824
> Demonstration that data is valid:
> pod=# select astext(the_point) from foo;
> astext
> POINT(-90 45)
> POINT(-149.1323 61.5982)
> (2 rows)
> Test data used:
> pod=# select * from foo;
> id | the_point
> | the_point3
> 2 | 0000000001C0568000000000004046800000000000 |
> 0080000001C05680000000000040468000000000000000000000000000
> 1 | 0000000001C062A43BCD35A858404ECC91D14E3BCD |
> 0080000001C062A43BCD35A858404ECC91D14E3BCD0000000000000000
> (2 rows)
> pod=# select version();
> version
> PostgreSQL 8.1.1 on sparc-sun-solaris2.9, compiled by GCC gcc (GCC)
> 3.4.3
> (1 row)
> pod=# select postgis_full_version();
> POSTGIS="1.1.1" GEOS="2.2.1-CAPI-1.0.1" PROJ="Rel. 4.4.9, 29 Oct
> 2004" USE_STATS
> (1 row)
> bash-2.05$ ldd liblwgeom.so
> libgeos_c.so.1 => /usr/local/geos/lib/libgeos_c.so.1
> libproj.so.0 => /usr/local/proj4/lib/libproj.so.0
> libgcc_s.so.1 => /usr/local/gcc/lib/sparcv9/
> libgcc_s.so.1
> libgeos.so.2 => /usr/local/geos/lib/libgeos.so.2
> libstdc++.so.6 => /usr/local/gcc-3.4.3-v9/lib/sparcv9/
> libstdc++.so.6
> libm.so.1 => /usr/lib/64/libm.so.1
> libc.so.1 => /usr/lib/64/libc.so.1
> libdl.so.1 => /usr/lib/64/libdl.so.1
> /usr/platform/SUNW,Sun-Fire-V240/lib/sparcv9/libc_psr.so.1
> bash-2.05$ cat /etc/release
> Solaris 9 9/05 s9s_u8wos_05 SPARC
> bash-2.05$ uname -a
> SunOS machine 5.9 Generic_118558-11 sun4u sparc SUNW,Sun-Fire-V240
> gcc (GCC) 3.4.3
> postgis-users mailing list
