[postgis-users] Amoeba Hulls
Paul Ramsey
pramsey at refractions.net
Wed Jul 5 11:26:48 PDT 2006
So my guess is that you use drive-time to segment your population of
customers relative to the store into the "nearest X%" and then draw a
"shape" around that cloud of points. And drawing the shape is the "fun"
part.
William Andersen wrote:
> It appears to be the same as this functionality in Business Analyst
> http://www.esri.com/software/arcgis/extensions/businessanalyst/about/customer-market.html
> <http://www.esri.com/software/arcgis/extensions/businessanalyst/about/customer-market.html>
> I thought this was done using some older version of Arcview, but i'm not
> very familiar with esri's offerings.
> Will
> On 7/5/06, *Paul Ramsey * <pramsey at refractions.net
> <mailto:pramsey at refractions.net>> wrote:
> This wouldn't be in vanilla arcview, was it in Network Analyst? The top
> 80% of points by drive distance might yield this shape. Finding the
> points would be straightforward, and then the hull building would be the
> hand-waving part.
> P
> > Paul, Steve,
> > Thanks for the quick replies, unfortunately it's pretty hard to tell
> > from those images if they match.
> > I've done some more digging and it turns out that these shapes were
> > created in Arcview 3.x. The notes I have say...
> > > This approach selects a number of the outliers and joins the
> extreme
> > points using elliptical arcs.
> > > The arcs are all created in a direction moving out from the
> store.
> > However, I dont see customer points at the discontinuities in the
> hulls,
> > so it appears that the "extreme points" are perhaps interpolated.
> > Will
> > On 7/5/06, *Paul Ramsey* < pramsey at refractions.net
> <mailto:pramsey at refractions.net>>> wrote:
> > William,
> > It doesn't look like this is a standard algorithm, but more
> likely a
> > particular empirical technique provided by the particular
> software you
> > were using. So substituting some other technique might yield a
> > different shape entirely... do any of the techniques
> mentioned here
> <http://www.geospatial-online.com/geospatialsolutions/article/articleDetail.jsp?id=1348
> http://www.geospatial-online.com/geospatialsolutions/article/articleDetail.jsp?id=1348>>
> > sound like what was done to your data?
> > Paul
> > > I'm fairly new to postgis, and working to automate a number of
> > > processes.
> > > We are trying to compute market area polygons that look
> like the
> > > attached image. These were created by some older software.
> > > They are referred to as Amoeba Hulls, and they contain 80%
> of a
> > > store's customers. However I can't find any solid
> documentation that
> > > would allow me to reproduce them.
> > > Does anyone have any ideas how these shapes are created or an
> > > alternate name that I might be able to google?
> Additionally, we may
> > > be in a position to finance the development of this feature.
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> <mailto:postgis-users at postgis.refractions.net>
> <mailto:postgis-users at postgis.refractions.net>>
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
