[postgis-users] Amoeba Hulls
Mike Leahy
mgleahy at alumni.uwaterloo.ca
Wed Jul 5 12:11:39 PDT 2006
Hey there,
If you can determine the closest 80% of points by whatever criteria,
wouldn't you be able to use the convexhull() function? I just tried
this, and it looks okay to me:
testdb=# select astext(convexhull('MULTIPOINT((0 1),(0 0),(1 0),(1
1))'::geometry));
astext
POLYGON((0 0,0 1,1 1,1 0,0 0))
(1 row)
I did the same thing after creating a points table with the separate in
individual records with the same overall coordinates in the multipoint
example above, and it worked okay too:
testdb=# select astext(convexhull(collect(p))) from testpoint;
astext
(1 row)
It wouldn't be too hard to modify this to work using where condition
that filters out the records of interest...or maybe on a saved view.
The only problem is that it wouldn't produce a nice curvy polygon
outline like in the sample William provided.
Regards,
Mike
Paul Ramsey wrote:
> So my guess is that you use drive-time to segment your population of
> customers relative to the store into the "nearest X%" and then draw a
> "shape" around that cloud of points. And drawing the shape is the "fun"
> part.
> William Andersen wrote:
>> It appears to be the same as this functionality in Business Analyst
>> http://www.esri.com/software/arcgis/extensions/businessanalyst/about/customer-market.html
>> <http://www.esri.com/software/arcgis/extensions/businessanalyst/about/customer-market.html>
>> I thought this was done using some older version of Arcview, but i'm
>> not very familiar with esri's offerings.
>> Will
>> On 7/5/06, *Paul Ramsey * <pramsey at refractions.net
>> <mailto:pramsey at refractions.net>> wrote:
>> This wouldn't be in vanilla arcview, was it in Network Analyst?
>> The top
>> 80% of points by drive distance might yield this shape. Finding the
>> points would be straightforward, and then the hull building would
>> be the
>> hand-waving part.
>> P
>> > Paul, Steve,
>> > Thanks for the quick replies, unfortunately it's pretty hard to
>> tell
>> > from those images if they match.
>> > I've done some more digging and it turns out that these shapes
>> were
>> > created in Arcview 3.x. The notes I have say...
>> > > This approach selects a number of the outliers and joins the
>> extreme
>> > points using elliptical arcs.
>> > > The arcs are all created in a direction moving out from the
>> store.
>> > However, I dont see customer points at the discontinuities in the
>> hulls,
>> > so it appears that the "extreme points" are perhaps interpolated.
>> > Will
>> > On 7/5/06, *Paul Ramsey* < pramsey at refractions.net
>> <mailto:pramsey at refractions.net>>> wrote:
>> > William,
>> > It doesn't look like this is a standard algorithm, but more
>> likely a
>> > particular empirical technique provided by the particular
>> software you
>> > were using. So substituting some other technique might
>> yield a
>> > different shape entirely... do any of the techniques
>> mentioned here
>> <http://www.geospatial-online.com/geospatialsolutions/article/articleDetail.jsp?id=1348
>> http://www.geospatial-online.com/geospatialsolutions/article/articleDetail.jsp?id=1348>>
>> > sound like what was done to your data?
>> > Paul
>> > > I'm fairly new to postgis, and working to automate a
>> number of
>> > > processes.
>> > > We are trying to compute market area polygons that look
>> like the
>> > > attached image. These were created by some older software.
>> > > They are referred to as Amoeba Hulls, and they contain 80%
>> of a
>> > > store's customers. However I can't find any solid
>> documentation that
>> > > would allow me to reproduce them.
>> > > Does anyone have any ideas how these shapes are created
>> or an
>> > > alternate name that I might be able to google?
>> Additionally, we may
>> > > be in a position to finance the development of this
>> feature.
>> > _______________________________________________
>> > postgis-users mailing list
>> > postgis-users at postgis.refractions.net
>> <mailto:postgis-users at postgis.refractions.net>
>> <mailto:postgis-users at postgis.refractions.net>>
>> > http://postgis.refractions.net/mailman/listinfo/postgis-users
