[postgis-users] Amoeba Hulls
William Andersen
wkandersen at gmail.com
Wed Jul 5 12:40:24 PDT 2006
Thanks for all the suggestions, they are giving me a lot to think about.
Unfortunately it's not always a convex hull. More complex patterns appear to
have wedges taken out of them, like you can see in this image
http://www.esri.com/software/arcgis/extensions/businessanalyst/graphics/market-boundaries-lg.jpg
It appears that, in our case, the hulls contain the 80% of closest members
as the crow flies (although some of the examples i've seen online seem to
use drivetimes). Then they somehow construct a polygon that contains exactly
those 80% and none of the remaining 20% - are there any standard routines
for that? Presumably once they've got that polygon they replace the line
segments with curves.
If i can create something that meets the same rules and has a similar "look"
then i'm sure it would suffice.
Graham
On 7/5/06, Mike Leahy <mgleahy at alumni.uwaterloo.ca> wrote:
> Hey there,
> If you can determine the closest 80% of points by whatever criteria,
> wouldn't you be able to use the convexhull() function? I just tried
> this, and it looks okay to me:
> testdb=# select astext(convexhull('MULTIPOINT((0 1),(0 0),(1 0),(1
> 1))'::geometry));
> astext
> POLYGON((0 0,0 1,1 1,1 0,0 0))
> (1 row)
> I did the same thing after creating a points table with the separate in
> individual records with the same overall coordinates in the multipoint
> example above, and it worked okay too:
> testdb=# select astext(convexhull(collect(p))) from testpoint;
> astext
> (1 row)
> It wouldn't be too hard to modify this to work using where condition
> that filters out the records of interest...or maybe on a saved view.
> The only problem is that it wouldn't produce a nice curvy polygon
> outline like in the sample William provided.
> Regards,
> Mike
> Paul Ramsey wrote:
> > So my guess is that you use drive-time to segment your population of
> > customers relative to the store into the "nearest X%" and then draw a
> > "shape" around that cloud of points. And drawing the shape is the "fun"
> > part.
> > William Andersen wrote:
> >> It appears to be the same as this functionality in Business Analyst
> http://www.esri.com/software/arcgis/extensions/businessanalyst/about/customer-market.html
> >> I thought this was done using some older version of Arcview, but i'm
> >> not very familiar with esri's offerings.
> >> Will
> >> On 7/5/06, *Paul Ramsey * <pramsey at refractions.net
> >> <mailto:pramsey at refractions.net>> wrote:
> >> This wouldn't be in vanilla arcview, was it in Network Analyst?
> >> The top
> >> 80% of points by drive distance might yield this shape. Finding
> the
> >> points would be straightforward, and then the hull building would
> >> be the
> >> hand-waving part.
> >> P
> >> > Paul, Steve,
> >> > Thanks for the quick replies, unfortunately it's pretty hard to
> >> tell
> >> > from those images if they match.
> >> > I've done some more digging and it turns out that these shapes
> >> were
> >> > created in Arcview 3.x. The notes I have say...
> >> > > This approach selects a number of the outliers and joins the
> >> extreme
> >> > points using elliptical arcs.
> >> > > The arcs are all created in a direction moving out from the
> >> store.
> >> > However, I dont see customer points at the discontinuities in
> the
> >> hulls,
> >> > so it appears that the "extreme points" are perhaps
> interpolated.
> >> > Will
> >> > On 7/5/06, *Paul Ramsey* < pramsey at refractions.net
> >> <mailto:pramsey at refractions.net>>> wrote:
> >> > William,
> >> > It doesn't look like this is a standard algorithm, but more
> >> likely a
> >> > particular empirical technique provided by the particular
> >> software you
> >> > were using. So substituting some other technique might
> >> yield a
> >> > different shape entirely... do any of the techniques
> >> mentioned here
> http://www.geospatial-online.com/geospatialsolutions/article/articleDetail.jsp?id=1348
> >> > sound like what was done to your data?
> >> > Paul
> >> > > I'm fairly new to postgis, and working to automate a
> >> number of
> >> > > processes.
> >> > > We are trying to compute market area polygons that look
> >> like the
> >> > > attached image. These were created by some older
> software.
> >> > > They are referred to as Amoeba Hulls, and they contain
> 80%
> >> of a
> >> > > store's customers. However I can't find any solid
> >> documentation that
> >> > > would allow me to reproduce them.
> >> > > Does anyone have any ideas how these shapes are created
> >> or an
> >> > > alternate name that I might be able to google?
> >> Additionally, we may
> >> > > be in a position to finance the development of this
> >> feature.
> >> > _______________________________________________
> >> > postgis-users mailing list
> >> > postgis-users at postgis.refractions.net
> >> <mailto:postgis-users at postgis.refractions.net>
> >> <mailto:postgis-users at postgis.refractions.net>>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060705/20e4057a/attachment.html>
