[postgis-users] Amoeba Hulls
Mike Leahy mgleahy at alumni.uwaterloo.ca
Wed Jul 5 15:24:04 PDT 2006
Hello again,
Here's another idea...what about creating a TIN from your point sets?  I
don't know if this has been done in PostGIS yet, but I'm pretty sure you
could find one or more algorithms for generating a TIN in various
spatial analysis textbooks, or online somewhere.
If you can make a TIN, then your area of interest could be generated by
the geomunion of all triangles in the TIN where all three of triangle's
vertices are one of the 80% closest points.  If I'm thinking right, then
this should produce a shape that is not necessarily convex.  Does that
sound right to anyone else?
Just thought I'd put the idea out there...
Mike
William Andersen wrote:
> Steve,
> I think you are onto something.
> There are exactly 101 points in each of the polygons in the (small)
> sample set that I have.
> When i get a little more time i'll plot these with 3.6 degree wedges and
> see if anything jumps out at me.
> My working theory is that there are a set of rules determining what
> happens at each control point. In some cases it's pretty simple as we
> have enough points to pick one that includes the 80% points but not the
> 20% points. In other cases it seems to be extrapolated from the
> neighboring points using some kind of fitted curve.
> Will
> On 7/5/06, *Stephen Woodbridge* <woodbri at swoodbridge.com
> <mailto:woodbri at swoodbridge.com>> wrote:
>     Paul,
>     Would you not just connect the dots, like this.
>     1) determine the 80% points, say by distance or whatever
>     2) order the points by radial angle increasing and radius decreasing
>     3) use something like a window say plus/minus 1/2 degree and select the
>     maximum radius in the window and add that point to the polygon
>     4) step 1/2 degree and repeat 3)
>     5) close the polygon
>     You probably need to have some special handling if there is a sudden
>     change in radius to make sure no points get clicked out of the polygon.
>     Anyway I think this would be a good start to the algorithm.
>     -Steve
>     Paul Ramsey wrote:
>      > Indeed, nice to see that everything can be strung together.  I am
>     trying
>      > to visualize what a "squishyhull" function would have to do to work
>      > though :)  It's a not uncommon request... the calculated
>     equivalent of
>      > someone squinting and drawing a line around a group of points.
>      > P
>      > Mike Leahy wrote:
>      >> Hey there,
>      >> If you can determine the closest 80% of points by whatever criteria,
>      >> wouldn't you be able to use the convexhull() function?  I just tried
>      >> this, and it looks okay to me:
>      >> testdb=# select astext(convexhull('MULTIPOINT((0 1),(0 0),(1 0),(1
>      >> 1))'::geometry));
>      >>              astext
>      >>  POLYGON((0 0,0 1,1 1,1 0,0 0))
>      >> (1 row)
>      >> I did the same thing after creating a points table with the separate
>      >> in individual records with the same overall coordinates in the
>      >> multipoint example above, and it worked okay too:
>      >> testdb=# select astext(convexhull(collect(p))) from testpoint;
>      >>              astext
>      >> (1 row)
>      >> It wouldn't be too hard to modify this to work using where condition
>      >> that filters out the records of interest...or maybe on a saved view.
>      >> The only problem is that it wouldn't produce a nice curvy polygon
>      >> outline like in the sample William provided.
>      >> Regards,
>      >> Mike
>      >> Paul Ramsey wrote:
>      >>> So my guess is that you use drive-time to segment your
>     population of
>      >>> customers relative to the store into the "nearest X%" and then
>     draw a
>      >>> "shape" around that cloud of points.  And drawing the shape is the
>      >>> "fun" part.
>      >>>> It appears to be the same as this functionality in Business
>     Analyst
>     http://www.esri.com/software/arcgis/extensions/businessanalyst/about/customer-market.html
>     <http://www.esri.com/software/arcgis/extensions/businessanalyst/about/customer-market.html
>     <http://www.esri.com/software/arcgis/extensions/businessanalyst/about/customer-market.html>>
>      >>>> I thought this was done using some older version of Arcview,
>     but i'm
>      >>>> not very familiar with esri's offerings.
>      >>>> Will
>      >>>> On 7/5/06, *Paul Ramsey * <pramsey at refractions.net
>     <mailto:pramsey at refractions.net>
>      >>>> <mailto: pramsey at refractions.net
>     <mailto:pramsey at refractions.net>>> wrote:
>      >>>>     This wouldn't be in vanilla arcview, was it in Network
>     Analyst?
>      >>>> The top
>      >>>>     80% of points by drive distance might yield this
>     shape.  Finding
>      >>>> the
>      >>>>     points would be straightforward, and then the hull building
>      >>>> would be the
>      >>>>     hand-waving part.
>      >>>>     P
>      >>>>      > Paul, Steve,
>      >>>>      > Thanks for the quick replies, unfortunately it's pretty
>     hard
>      >>>> to tell
>      >>>>      > from those images if they match.
>      >>>>      > I've done some more digging and it turns out that these
>      >>>> shapes were
>      >>>>      > created in Arcview 3.x. The notes I have say...
>      >>>>      >  > This approach selects a number of the outliers and
>     joins the
>      >>>>     extreme
>      >>>>      > points using elliptical arcs.
>      >>>>      >  > The arcs are all created in a direction moving out
>     from the
>      >>>>     store.
>      >>>>      > However, I dont see customer points at the
>     discontinuities in
>      >>>> the
>      >>>>     hulls,
>      >>>>      > so it appears that the "extreme points" are perhaps
>      >>>> interpolated.
>      >>>>      > Will
>      >>>>      > On 7/5/06, *Paul Ramsey* < pramsey at refractions.net
>     <mailto:pramsey at refractions.net>>>> wrote:
>      >>>>      >     William,
>      >>>>      >     It doesn't look like this is a standard algorithm,
>     but more
>      >>>>     likely a
>      >>>>      >     particular empirical technique provided by the
>     particular
>      >>>>     software you
>      >>>>      >     were using.  So substituting some other technique might
>      >>>> yield a
>      >>>>      >     different shape entirely... do any of the techniques
>      >>>>     mentioned here
>     <http://www.geospatial-online.com/geospatialsolutions/article/articleDetail.jsp?id=1348
>     <http://www.geospatial-online.com/geospatialsolutions/article/articleDetail.jsp?id=1348>
>     <http://www.geospatial-online.com/geospatialsolutions/article/articleDetail.jsp?id=1348>>>
>      >>>>      >     sound like what was done to your data?
>      >>>>      >     Paul
>      >>>>      >      > I'm fairly new to postgis, and working to automate a
>      >>>> number of
>      >>>>      >      > processes.
>      >>>>      >      > We are trying to compute market area polygons
>     that look
>      >>>>     like the
>      >>>>      >      > attached image. These were created by some older
>      >>>> software.
>      >>>>      >      > They are referred to as Amoeba Hulls, and they
>     contain
>      >>>> 80%
>      >>>>     of a
>      >>>>      >      > store's customers. However I can't find any solid
>      >>>>     documentation that
>      >>>>      >      > would allow me to reproduce them.
>      >>>>      >      > Does anyone have any ideas how these shapes are
>      >>>> created or an
>      >>>>      >      > alternate name that I might be able to google?
>      >>>>     Additionally, we may
>      >>>>      >      > be in a position to finance the development of this
>      >>>> feature.
>      >>>>      >     _______________________________________________
>      >>>>      >     postgis-users mailing list
>      >>>>      >     postgis-users at postgis.refractions.net
>     <mailto:postgis-users at postgis.refractions.net>
>      >>>>     <mailto: postgis-users at postgis.refractions.net
>     <mailto:postgis-users at postgis.refractions.net>>
>     <mailto:postgis-users at postgis.refractions.net>>>
>      >>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>     <http://postgis.refractions.net/mailman/listinfo/postgis-users>
