[postgis-users] Amoeba Hulls
Bruce Rindahl
rindahl at lrcwe.com
Wed Jul 5 15:16:54 PDT 2006
Maybe:
1: Find distance to 80% of customers via network analysis.
2: Use that distance to find all points along network at that distance
3: Form polygon from points in 2
Bruce
_____
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Josh at oklieb
Sent: Wednesday, July 05, 2006 4:07 PM
To: PostGIS Discussion
Subject: Re: [postgis-users] Amoeba Hulls
Notice that the boundary in the supplied figure curves even in the absence
of any controlling points. That usually means to me that there is a surface
function at work and the line is a contour, here containing 80% of the
customer "volume". I know that I've used geostatistics modules in Arcview 3
(way back when) and this may be a similar approach.
Josh Lieberman
On Jul 5, 2006, at 4:40 PM, Bruce Rindahl wrote:
Will
Did you create this using ArcView 3.x Business Analyst? If so, the Avenue
code is available from that interface. That could give us a guide on how it
was created.
Bruce Rindahl
_____
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of William
Andersen
Sent: Wednesday, July 05, 2006 2:15 PM
To: PostGIS Users Discussion
Steve,
I think you are onto something.
There are exactly 101 points in each of the polygons in the (small) sample
set that I have.
When i get a little more time i'll plot these with 3.6 degree wedges and see
if anything jumps out at me.
My working theory is that there are a set of rules determining what happens
at each control point. In some cases it's pretty simple as we have enough
points to pick one that includes the 80% points but not the 20% points. In
other cases it seems to be extrapolated from the neighboring points using
some kind of fitted curve.
Will
On 7/5/06, Stephen Woodbridge <woodbri at swoodbridge.com> wrote:
Paul,
Would you not just connect the dots, like this.
1) determine the 80% points, say by distance or whatever
2) order the points by radial angle increasing and radius decreasing
3) use something like a window say plus/minus 1/2 degree and select the
maximum radius in the window and add that point to the polygon
4) step 1/2 degree and repeat 3)
5) close the polygon
You probably need to have some special handling if there is a sudden
change in radius to make sure no points get clicked out of the polygon.
Anyway I think this would be a good start to the algorithm.
-Steve
Paul Ramsey wrote:
> Indeed, nice to see that everything can be strung together. I am trying
> to visualize what a "squishyhull" function would have to do to work
> though :) It's a not uncommon request... the calculated equivalent of
> someone squinting and drawing a line around a group of points.
> P
> Mike Leahy wrote:
>> Hey there,
>> If you can determine the closest 80% of points by whatever criteria,
>> wouldn't you be able to use the convexhull() function? I just tried
>> this, and it looks okay to me:
>> testdb=# select astext(convexhull('MULTIPOINT((0 1),(0 0),(1 0),(1
>> 1))'::geometry));
>> astext
>> POLYGON((0 0,0 1,1 1,1 0,0 0))
>> (1 row)
>> I did the same thing after creating a points table with the separate
>> in individual records with the same overall coordinates in the
>> multipoint example above, and it worked okay too:
>> testdb=# select astext(convexhull(collect(p))) from testpoint;
>> astext
>> (1 row)
>> It wouldn't be too hard to modify this to work using where condition
>> that filters out the records of interest...or maybe on a saved view.
>> The only problem is that it wouldn't produce a nice curvy polygon
>> outline like in the sample William provided.
>> Regards,
>> Mike
>> Paul Ramsey wrote:
>>> So my guess is that you use drive-time to segment your population of
>>> customers relative to the store into the "nearest X%" and then draw a
>>> "shape" around that cloud of points. And drawing the shape is the
>>> "fun" part.
>>> William Andersen wrote:
>>>> It appears to be the same as this functionality in Business Analyst
http://www.esri.com/software/arcgis/extensions/businessanalyst/about/custome
r-market.html
<http://www.esri.com/software/arcgis/extensions/businessanalyst/about/custom
er-market.html >
>>>> I thought this was done using some older version of Arcview, but i'm
>>>> not very familiar with esri's offerings.
>>>> Will
>>>> On 7/5/06, *Paul Ramsey * <pramsey at refractions.net
>>>> <mailto: <mailto:pramsey at refractions.net> pramsey at refractions.net>>
wrote:
>>>> This wouldn't be in vanilla arcview, was it in Network Analyst?
>>>> The top
>>>> 80% of points by drive distance might yield this shape. Finding
>>>> the
>>>> points would be straightforward, and then the hull building
>>>> would be the
>>>> hand-waving part.
>>>> P
>>>> > Paul, Steve,
>>>> > Thanks for the quick replies, unfortunately it's pretty hard
>>>> to tell
>>>> > from those images if they match.
>>>> > I've done some more digging and it turns out that these
>>>> shapes were
>>>> > created in Arcview 3.x. The notes I have say...
>>>> > > This approach selects a number of the outliers and joins the
>>>> extreme
>>>> > points using elliptical arcs.
>>>> > > The arcs are all created in a direction moving out from the
>>>> store.
>>>> > However, I dont see customer points at the discontinuities in
>>>> the
>>>> hulls,
>>>> > so it appears that the "extreme points" are perhaps
>>>> interpolated.
>>>> > Will
>>>> > On 7/5/06, *Paul Ramsey* < pramsey at refractions.net
>>>> <mailto:pramsey at refractions.net>>> wrote:
>>>> > William,
>>>> > It doesn't look like this is a standard algorithm, but more
>>>> likely a
>>>> > particular empirical technique provided by the particular
>>>> software you
>>>> > were using. So substituting some other technique might
>>>> yield a
>>>> > different shape entirely... do any of the techniques
>>>> mentioned here
<http://www.geospatial-online.com/geospatialsolutions/article/articleDetail.
jsp?id=1348
http://www.geospatial-online.com/geospatialsolutions/article/articleDetail.j
sp?id=1348 >>
>>>> > sound like what was done to your data?
>>>> > Paul
>>>> > > I'm fairly new to postgis, and working to automate a
>>>> number of
>>>> > > processes.
>>>> > > We are trying to compute market area polygons that look
>>>> like the
>>>> > > attached image. These were created by some older
>>>> software.
>>>> > > They are referred to as Amoeba Hulls, and they contain
>>>> 80%
>>>> of a
>>>> > > store's customers. However I can't find any solid
>>>> documentation that
>>>> > > would allow me to reproduce them.
>>>> > > Does anyone have any ideas how these shapes are
>>>> created or an
>>>> > > alternate name that I might be able to google?
>>>> Additionally, we may
>>>> > > be in a position to finance the development of this
>>>> feature.
>>>> > _______________________________________________
>>>> > postgis-users mailing list
>>>> > postgis-users at postgis.refractions.net
>>>> <mailto: postgis-users at postgis.refractions.net>
>>>> > <mailto:postgis-users at postgis.refractions.net
>>>> <mailto:postgis-users at postgis.refractions.net>>
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>>>> <mailto:postgis-users at postgis.refractions.net >
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060705/cd20c60b/attachment.html>
