[postgis-users] Amoeba Hulls
Josh@oklieb
josh at oklieb.net
Wed Jul 5 15:06:56 PDT 2006
Notice that the boundary in the supplied figure curves even in the
absence of any controlling points. That usually means to me that
there is a surface function at work and the line is a contour, here
containing 80% of the customer "volume". I know that I've used
geostatistics modules in Arcview 3 (way back when) and this may be a
similar approach.
Josh Lieberman
On Jul 5, 2006, at 4:40 PM, Bruce Rindahl wrote:
> Will
> Did you create this using ArcView 3.x Business Analyst? If so, the
> Avenue code is available from that interface. That could give us a
> guide on how it was created.
> Bruce Rindahl
> From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-
> users-bounces at postgis.refractions.net] On Behalf Of William Andersen
> Sent: Wednesday, July 05, 2006 2:15 PM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] Amoeba Hulls
> Steve,
> I think you are onto something.
> There are exactly 101 points in each of the polygons in the (small)
> sample set that I have.
> When i get a little more time i'll plot these with 3.6 degree
> wedges and see if anything jumps out at me.
> My working theory is that there are a set of rules determining what
> happens at each control point. In some cases it's pretty simple as
> we have enough points to pick one that includes the 80% points but
> not the 20% points. In other cases it seems to be extrapolated from
> the neighboring points using some kind of fitted curve.
> Will
> On 7/5/06, Stephen Woodbridge <woodbri at swoodbridge.com> wrote:
> Paul,
> Would you not just connect the dots, like this.
> 1) determine the 80% points, say by distance or whatever
> 2) order the points by radial angle increasing and radius decreasing
> 3) use something like a window say plus/minus 1/2 degree and select
> the
> maximum radius in the window and add that point to the polygon
> 4) step 1/2 degree and repeat 3)
> 5) close the polygon
> You probably need to have some special handling if there is a sudden
> change in radius to make sure no points get clicked out of the
> polygon.
> Anyway I think this would be a good start to the algorithm.
> -Steve
> Paul Ramsey wrote:
> > Indeed, nice to see that everything can be strung together. I am
> trying
> > to visualize what a "squishyhull" function would have to do to work
> > though :) It's a not uncommon request... the calculated
> equivalent of
> > someone squinting and drawing a line around a group of points.
> > P
> > Mike Leahy wrote:
> >> Hey there,
> >> If you can determine the closest 80% of points by whatever
> criteria,
> >> wouldn't you be able to use the convexhull() function? I just
> tried
> >> this, and it looks okay to me:
> >> testdb=# select astext(convexhull('MULTIPOINT((0 1),(0 0),(1 0),(1
> >> 1))'::geometry));
> >> astext
> >> POLYGON((0 0,0 1,1 1,1 0,0 0))
> >> (1 row)
> >> I did the same thing after creating a points table with the
> separate
> >> in individual records with the same overall coordinates in the
> >> multipoint example above, and it worked okay too:
> >> testdb=# select astext(convexhull(collect(p))) from testpoint;
> >> astext
> >> (1 row)
> >> It wouldn't be too hard to modify this to work using where
> condition
> >> that filters out the records of interest...or maybe on a saved
> view.
> >> The only problem is that it wouldn't produce a nice curvy polygon
> >> outline like in the sample William provided.
> >> Regards,
> >> Mike
> >> Paul Ramsey wrote:
> >>> So my guess is that you use drive-time to segment your
> population of
> >>> customers relative to the store into the "nearest X%" and then
> draw a
> >>> "shape" around that cloud of points. And drawing the shape is the
> >>> "fun" part.
> >>> William Andersen wrote:
> >>>> It appears to be the same as this functionality in Business
> Analyst
> >>>> http://www.esri.com/software/arcgis/extensions/businessanalyst/
> about/customer-market.html
> >>>> <http://www.esri.com/software/arcgis/extensions/
> businessanalyst/about/customer-market.html >
> >>>> I thought this was done using some older version of Arcview,
> but i'm
> >>>> not very familiar with esri's offerings.
> >>>> Will
> >>>> On 7/5/06, *Paul Ramsey * <pramsey at refractions.net
> >>>> <mailto: pramsey at refractions.net>> wrote:
> >>>> This wouldn't be in vanilla arcview, was it in Network
> Analyst?
> >>>> The top
> >>>> 80% of points by drive distance might yield this shape.
> Finding
> >>>> the
> >>>> points would be straightforward, and then the hull building
> >>>> would be the
> >>>> hand-waving part.
> >>>> P
> >>>> > Paul, Steve,
> >>>> > Thanks for the quick replies, unfortunately it's pretty
> hard
> >>>> to tell
> >>>> > from those images if they match.
> >>>> > I've done some more digging and it turns out that these
> >>>> shapes were
> >>>> > created in Arcview 3.x. The notes I have say...
> >>>> > > This approach selects a number of the outliers and
> joins the
> >>>> extreme
> >>>> > points using elliptical arcs.
> >>>> > > The arcs are all created in a direction moving out
> from the
> >>>> store.
> >>>> > However, I dont see customer points at the
> discontinuities in
> >>>> the
> >>>> hulls,
> >>>> > so it appears that the "extreme points" are perhaps
> >>>> interpolated.
> >>>> > Will
> >>>> > On 7/5/06, *Paul Ramsey* < pramsey at refractions.net
> >>>> <mailto:pramsey at refractions.net>
> >>>> <mailto:pramsey at refractions.net>>> wrote:
> >>>> > William,
> >>>> > It doesn't look like this is a standard algorithm,
> but more
> >>>> likely a
> >>>> > particular empirical technique provided by the
> particular
> >>>> software you
> >>>> > were using. So substituting some other technique
> might
> >>>> yield a
> >>>> > different shape entirely... do any of the techniques
> >>>> mentioned here
> >>>> <http://www.geospatial-online.com/geospatialsolutions/article/
> articleDetail.jsp?id=1348
> articleDetail.jsp?id=1348 >>
> >>>> > sound like what was done to your data?
> >>>> > Paul
> >>>> > > I'm fairly new to postgis, and working to
> automate a
> >>>> number of
> >>>> > > processes.
> >>>> > > We are trying to compute market area polygons
> that look
> >>>> like the
> >>>> > > attached image. These were created by some older
> >>>> software.
> >>>> > > They are referred to as Amoeba Hulls, and they
> contain
> >>>> 80%
> >>>> of a
> >>>> > > store's customers. However I can't find any solid
> >>>> documentation that
> >>>> > > would allow me to reproduce them.
> >>>> > > Does anyone have any ideas how these shapes are
> >>>> created or an
> >>>> > > alternate name that I might be able to google?
> >>>> Additionally, we may
> >>>> > > be in a position to finance the development of this
> >>>> feature.
> >>>> > _______________________________________________
> >>>> > postgis-users mailing list
> >>>> > postgis-users at postgis.refractions.net
> >>>> <mailto: postgis-users at postgis.refractions.net>
> >>>> > <mailto:postgis-users at postgis.refractions.net
> >>>> <mailto:postgis-users at postgis.refractions.net>>
> >>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> users
> >>>> <mailto:postgis-users at postgis.refractions.net >
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060705/872e48f0/attachment.html>
