[postgis-users] Amoeba Hulls
    William Andersen
    wkandersen at gmail.com
    Wed Jul  5 13:29:05 PDT 2006
Jessica,
That's definitely an interesting algorithm.
Unfortunately I believe that for a given alpha there wouldn't be a way to
assert that exactly 80% of the points fell within the final shape. In
essence, the scoop might be too large to create the detail needed to keep
those 20% of points outside of the polygon.
Will
On 7/5/06, Jessica M Salmon <jmsalmon at fs.fed.us> wrote:
> William,
> We group points into polygons to generate fire perimeters from discrete
> active fire detections (from satellites images). To do this, we use an
> algorithm known as Alpha Shapes.
> http://n.ethz.ch/student/fischerk/alphashapes/as/
> The picture you reference below looks similar to these Alpha Shapes.
> I have not yet implemented this processing in our postgis database. If I
> do, I will post the function to the mailing list, but honestly it's not
> very high priority ATM.
> Cheers,
> Meghan
>              "William
>              Andersen"
>              <wkandersen at gmail                                          To
>              .com>                     "PostGIS Users Discussion"
>              Sent by:                  <postgis-users at postgis.refractions.
>              postgis-users-bou         net>
>              nces at postgis.refr                                          cc
>              actions.net
>        Subject
>                                        Re: [postgis-users] Amoeba Hulls
>              07/05/2006 01:40
>              PM
>              Please respond to
>                PostGIS Users
>                 Discussion
>              stgis.refractions
>                    .net>
> Thanks for all the suggestions, they are giving me a lot to think about.
> Unfortunately it's not always a convex hull. More complex patterns appear
> to have wedges taken out of them, like you can see in this image
> http://www.esri.com/software/arcgis/extensions/businessanalyst/graphics/market-boundaries-lg.jpg
> It appears that, in our case, the hulls contain the 80% of closest members
> as the crow flies (although some of the examples i've seen online seem to
> use drivetimes). Then they somehow construct a polygon that contains
> exactly those 80% and none of the remaining 20% - are there any standard
> routines for that? Presumably once they've got that polygon they replace
> the line segments with curves.
> If i can create something that meets the same rules and has a similar
> "look" then i'm sure it would suffice.
> Graham
> On 7/5/06, Mike Leahy <mgleahy at alumni.uwaterloo.ca> wrote:
>   Hey there,
>   If you can determine the closest 80% of points by whatever criteria,
>   wouldn't you be able to use the convexhull() function?  I just tried
>   this, and it looks okay to me:
>   testdb=# select astext(convexhull('MULTIPOINT((0 1),(0 0),(1 0),(1
>   1))'::geometry));
>                 astext
>     POLYGON((0 0,0 1,1 1,1 0,0 0))
>   (1 row)
>   I did the same thing after creating a points table with the separate in
>   individual records with the same overall coordinates in the multipoint
>   example above, and it worked okay too:
>   testdb=# select astext(convexhull(collect(p))) from testpoint;
>                 astext
>   (1 row)
>   It wouldn't be too hard to modify this to work using where condition
>   that filters out the records of interest...or maybe on a saved view.
>   The only problem is that it wouldn't produce a nice curvy polygon
>   outline like in the sample William provided.
>   Regards,
>   Mike
>   Paul Ramsey wrote:
>   > So my guess is that you use drive-time to segment your population of
>   > customers relative to the store into the "nearest X%" and then draw a
>   > "shape" around that cloud of points.  And drawing the shape is the
>   "fun"
>   > part.
>   > William Andersen wrote:
>   >> It appears to be the same as this functionality in Business Analyst
> http://www.esri.com/software/arcgis/extensions/businessanalyst/about/customer-market.html
>   >> I thought this was done using some older version of Arcview, but i'm
>   >> not very familiar with esri's offerings.
>   >> Will
>   >> On 7/5/06, *Paul Ramsey * < pramsey at refractions.net
>   >> <mailto:pramsey at refractions.net>> wrote:
>   >>     This wouldn't be in vanilla arcview, was it in Network Analyst?
>   >> The top
>   >>     80% of points by drive distance might yield this shape.  Finding
>   the
>   >>     points would be straightforward, and then the hull building would
>   >> be the
>   >>     hand-waving part.
>   >>     P
>   >>      > Paul, Steve,
>   >>      > Thanks for the quick replies, unfortunately it's pretty hard
> to
>   >> tell
>   >>      > from those images if they match.
>   >>      > I've done some more digging and it turns out that these shapes
>   >> were
>   >>      > created in Arcview 3.x. The notes I have say...
>   >>      >  > This approach selects a number of the outliers and joins
> the
>   >>     extreme
>   >>      > points using elliptical arcs.
>   >>      >  > The arcs are all created in a direction moving out from the
>   >>     store.
>   >>      > However, I dont see customer points at the discontinuities in
>   the
>   >>     hulls,
>   >>      > so it appears that the "extreme points" are perhaps
>   interpolated.
>   >>      > Will
>   >>      > On 7/5/06, *Paul Ramsey* < pramsey at refractions.net
>   >>     <mailto: pramsey at refractions.net>
>   >>     <mailto: pramsey at refractions.net>>> wrote:
>   >>      >     William,
>   >>      >     It doesn't look like this is a standard algorithm, but
> more
>   >>     likely a
>   >>      >     particular empirical technique provided by the particular
>   >>     software you
>   >>      >     were using.  So substituting some other technique might
>   >> yield a
>   >>      >     different shape entirely... do any of the techniques
>   >>     mentioned here
> http://www.geospatial-online.com/geospatialsolutions/article/articleDetail.jsp?id=1348
>   >>      >     sound like what was done to your data?
>   >>      >     Paul
>   >>      >      > I'm fairly new to postgis, and working to automate a
>   >> number of
>   >>      >      > processes.
>   >>      >      > We are trying to compute market area polygons that look
>   >>     like the
>   >>      >      > attached image. These were created by some older
>   software.
>   >>      >      > They are referred to as Amoeba Hulls, and they contain
>   80%
>   >>     of a
>   >>      >      > store's customers. However I can't find any solid
>   >>     documentation that
>   >>      >      > would allow me to reproduce them.
>   >>      >      > Does anyone have any ideas how these shapes are created
>   >> or an
>   >>      >      > alternate name that I might be able to google?
>   >>     Additionally, we may
>   >>      >      > be in a position to finance the development of this
>   >> feature.
>   >>      >     _______________________________________________
>   >>      >     postgis-users mailing list
>   >>      >     postgis-users at postgis.refractions.net
>   >>     <mailto:postgis-users at postgis.refractions.net >
>   >>     <mailto: postgis-users at postgis.refractions.net>>
>   http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060705/4138ba93/attachment.html>
