[postgis-users] Angle
Ezequias Rodrigues da Rocha
ezequias at recife.pe.gov.br
Thu Jul 6 10:05:26 PDT 2006
marco vieira escreveu:
> Ezequias:
> Look at postgis documentation. azimuth() returns radians, not
> degrees. You must divide by pi rad and multiply by 180 degrees to
> obtain 124,9 degrees. Make sure your azimuth is 143,9 by manual
> calculation using start and end points (make sure you are using the
> same start and end points).
> Regards.
> Marco Vieira
> +55 21 9499-6800
> e-mail: maovieira at gmail.com <mailto:maovieira at gmail.com>
> 2006/7/6, Ezequias Rodrigues da Rocha <ezequias at recife.pe.gov.br
> <mailto:ezequias at recife.pe.gov.br>>:
> Arnaud Lesauvage escreveu:
> > Ezequias Rodrigues da Rocha wrote:
> >> Ok, now I need to get the start and and point of a linestring
> >> feature. Could you tell me please ?
> >> Regards
> >> Ezequias
> >>>> Hi list,
> >>>> Could someone tell me how to get an angle of a linestring
> feature ?
> >>>> Regards...
> >>> The azimuth(geometry, geometry) function might be what you are
> >>> looking for.
> >>> Input geometries are points, so you might use
> >>> Azimuth(StartPoint(geometry), EndPoint(geometry)) if geometry is a
> >>> Linestring.
> >>> http://postgis.refractions.net/docs/ch06.html#id2528534
> <http://postgis.refractions.net/docs/ch06.html#id2528534>
> > What do you think these "StartPoint" and "EndPoint" functions do ?
> > Have you read the documentation at
> <http://postgis.refractions.net/docs/> ?
> > All you questions are answered there.
> > PS : Please, reply below the quotes. Thanks !
> > Arnaud
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> <mailto:postgis-users at postgis.refractions.net>
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
> <http://postgis.refractions.net/mailman/listinfo/postgis-users>
> Arnaud (great name. The name of my grandfather),
> I tried like this but the result (as you can see now) is too below.
> dbpotgis=# SELECT azimuth(startpoint(the_geom),endpoint(the_geom)) as
> azimuth from mub where gid = 2900;
> azimuth
> 2.17998093202836
> (1 row)
> dbpotgis=#
> The real angle is 143,9 and the function only rerutns 2.17...
> Could you tell me what I did wrong ?
> Regards ...
Marco,
I did the following:
DesiredDegree = 180 - ColumnInRad /PI * 1 rad
Whre 1 rad = 57.29577951
Some features works someothers dont.
Regards
Ezequias
