[postgis-users] Angle
Eduardo Luís Garcia Escovar eduardo.escovar at 3wt.com.br
Thu Jul 6 10:34:11 PDT 2006
Ezequias Rodrigues da Rocha escreveu:
> marco vieira escreveu:
>> Ezequias:
>>  Look at postgis documentation. azimuth() returns radians, not
>> degrees. You must divide by pi rad and multiply by 180 degrees to
>> obtain 124,9 degrees. Make sure your azimuth is 143,9 by manual
>> calculation using start and end points (make sure you are using the
>> same start and end points).
>> Regards.
>> Marco Vieira
>> +55 21 9499-6800
>> e-mail: maovieira at gmail.com <mailto:maovieira at gmail.com>
> Marco,
> I did the following:
> DesiredDegree = 180 - ColumnInRad /PI * 1 rad
> Whre 1 rad = 57.29577951
> Some features works someothers dont.
> Regards
> Ezequias
> postgis-users mailing list
Ezequias,
You should have done like Marco said:
DesiredDegree = ColumnInRad/pi( )*180
Remember, this result is the azimuth (angle from the north, i.e., from
the y axis, clockwise).
Hope this helps,
Eduardo
