[postgis-users] Angle
Ezequias Rodrigues da Rocha ezequias at recife.pe.gov.br
Thu Jul 6 11:56:04 PDT 2006
Eduardo Luís Garcia Escovar escreveu:
> Ezequias Rodrigues da Rocha escreveu:
>> marco vieira escreveu:
>>> Ezequias:
>>>  Look at postgis documentation. azimuth() returns radians, not
>>> degrees. You must divide by pi rad and multiply by 180 degrees to
>>> obtain 124,9 degrees. Make sure your azimuth is 143,9 by manual
>>> calculation using start and end points (make sure you are using the
>>> same start and end points).
>>> Regards.
>>> Marco Vieira
>>> +55 21 9499-6800
>>> e-mail: maovieira at gmail.com <mailto:maovieira at gmail.com>
>> Marco,
>> I did the following:
>> DesiredDegree = 180 - ColumnInRad /PI * 1 rad
>> Whre 1 rad = 57.29577951
>> Some features works someothers dont.
>> Regards
>> Ezequias
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> Ezequias,
> You should have done like Marco said:
> DesiredDegree = ColumnInRad/pi( )*180
> Remember, this result is the azimuth (angle from the north, i.e., from
> the y axis, clockwise).
> Hope this helps,
> Eduardo
Thank you Eduardo,
Could you see for yourself.
My feature is this one:
MULTILINESTRING ((290635.73828125 9108941.88085938, 290635.94921875
9108941.77929688, 290636.2890625 9108940.7109375, 290636.51953125
9108918.06054688, 290636.509765625 9108917.55078125, 290636.119140625
9108916.06054688, 290635.279296875 9108914.69921875, 290635.146484375
9108914.5703125))
The angle my Desktop GIS application says is (OpenJUMP): *91.76 degrees*
(from up to down)
The Azimuth generated by Postgis is:  3.16325843263936
The angle applying this formula (you suggested):  *181.241357699403 degrees
So what is wrong ?
Regards ...
http://ezequiasrocha.blogspot.com
msn:ezequias at hotmail.com
"the worst of democracies is still better than the best of dictatorship"
