[postgis-users] Angle
Eduardo Luís Garcia Escovar eduardo.escovar at 3wt.com.br
Thu Jul 6 13:05:34 PDT 2006
Ezequias Rodrigues da Rocha escreveu:
> Eduardo Luís Garcia Escovar escreveu:
>>> marco vieira escreveu:
>>>> Ezequias:
>>>>  Look at postgis documentation. azimuth() returns radians, not
>>>> degrees. You must divide by pi rad and multiply by 180 degrees to
>>>> obtain 124,9 degrees. Make sure your azimuth is 143,9 by manual
>>>> calculation using start and end points (make sure you are using the
>>>> same start and end points).
>>>> Regards.
>>>> Marco Vieira
>>>> +55 21 9499-6800
>>>> e-mail: maovieira at gmail.com <mailto:maovieira at gmail.com>
>>> Marco,
>>> I did the following:
>>> DesiredDegree = 180 - ColumnInRad /PI * 1 rad
>>> Whre 1 rad = 57.29577951
>>> Some features works someothers dont.
>>> Regards
>>> Ezequias
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> Ezequias,
>> You should have done like Marco said:
>> DesiredDegree = ColumnInRad/pi( )*180
>> Remember, this result is the azimuth (angle from the north, i.e.,
>> from the y axis, clockwise).
>> Hope this helps,
>> Eduardo
> Thank you Eduardo,
> Could you see for yourself.
> My feature is this one:
> MULTILINESTRING ((290635.73828125 9108941.88085938, 290635.94921875
> 9108941.77929688, 290636.2890625 9108940.7109375, 290636.51953125
> 9108918.06054688, 290636.509765625 9108917.55078125, 290636.119140625
> 9108916.06054688, 290635.279296875 9108914.69921875, 290635.146484375
> 9108914.5703125))
> The angle my Desktop GIS application says is (OpenJUMP): *91.76
> degrees* (from up to down)
> The Azimuth generated by Postgis is:  3.16325843263936
> The angle applying this formula (you suggested):  *181.241357699403
> degrees
> So what is wrong ?
> Regards ...
Ezequias,
I didn't understand what you meant by "from up to down". Watch the
picture in attached file, so you can see what is the meaning of the
azimuth function result.
Regards
Eduardo
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060706/1fd089f6/attachment.png>
