[postgis-users] Angle
Ezequias Rodrigues da Rocha
ezequias at recife.pe.gov.br
Fri Jul 7 05:19:12 PDT 2006
Now it is working perfect. Thank you Eduardo. Point finish. The X axis
here is not the same azimuth North axis and we only must to make some
changes to see the angle.
Thank you so much one more time.
ps: The image is perfect. You must post it on the wikipedia too.
Regards
Ezequias
Eduardo Luís Garcia Escovar escreveu:
> Ezequias Rodrigues da Rocha escreveu:
>>>> marco vieira escreveu:
>>>>> Ezequias:
>>>>> Look at postgis documentation. azimuth() returns radians, not
>>>>> degrees. You must divide by pi rad and multiply by 180 degrees to
>>>>> obtain 124,9 degrees. Make sure your azimuth is 143,9 by manual
>>>>> calculation using start and end points (make sure you are using
>>>>> the same start and end points).
>>>>> Regards.
>>>>> Marco Vieira
>>>>> +55 21 9499-6800
>>>>> e-mail: maovieira at gmail.com <mailto:maovieira at gmail.com>
>>>> Marco,
>>>> I did the following:
>>>> DesiredDegree = 180 - ColumnInRad /PI * 1 rad
>>>> Whre 1 rad = 57.29577951
>>>> Some features works someothers dont.
>>>> Regards
>>>> Ezequias
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> postgis-users at postgis.refractions.net
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>>> Ezequias,
>>> You should have done like Marco said:
>>> DesiredDegree = ColumnInRad/pi( )*180
>>> Remember, this result is the azimuth (angle from the north, i.e.,
>>> from the y axis, clockwise).
>>> Hope this helps,
>>> Eduardo
>> Thank you Eduardo,
>> Could you see for yourself.
>> My feature is this one:
>> MULTILINESTRING ((290635.73828125 9108941.88085938, 290635.94921875
>> 9108941.77929688, 290636.2890625 9108940.7109375, 290636.51953125
>> 9108918.06054688, 290636.509765625 9108917.55078125, 290636.119140625
>> 9108916.06054688, 290635.279296875 9108914.69921875, 290635.146484375
>> 9108914.5703125))
>> The angle my Desktop GIS application says is (OpenJUMP): *91.76
>> degrees* (from up to down)
>> The Azimuth generated by Postgis is: 3.16325843263936
>> The angle applying this formula (you suggested): *181.241357699403
>> degrees
>> So what is wrong ?
>> Regards ...
> Ezequias,
> I didn't understand what you meant by "from up to down". Watch the
> picture in attached file, so you can see what is the meaning of the
> azimuth function result.
> Regards
> Eduardo
http://ezequiasrocha.blogspot.com
msn:ezequias at hotmail.com
"the worst of democracies is still better than the best of dictatorship"
