[postgis-users] Cannot load lwpostgis.sql
strk at refractions.net strk at refractions.net
Mon Jul 10 09:44:23 PDT 2006
On Mon, Jul 10, 2006 at 04:33:37AM -0700, aleix wrote:
> I was a PostgreSQL and Postgis user on windows, but now I have changed to
> Linux (Ubuntu), and I have installed PostgreSQL 8.1.4. I installed it
> manually, and then I installed GEOS and Postgis without problems. Finally,
> when I started pgAdmin and tried to load lwpostgis.sql to load GEOS
> functions, i got this error:
> NOTICE:  type "histogram2d" is not yet defined
> DETAIL:  Creating a shell type definition.
> ERROR:  could not access file "$libdir/liblwgeom.so.1.1": No such file or
> directory found
It seems a missing make install ?
Or, what does postgis' ./configure report as EXT ?
Can you find liblwgeom.so.1.1 under that dir ?
--strk;
