[postgis-users] Who is Using PostGIS? For What?
Arjen Vrielink vrielink at sarvision.nl
Thu Jul 13 01:21:24 PDT 2006
Hi all, in repsonse to Paul's inquiry:
> Who are you?
Arjen Vrielink, working for SarVision, Wageningen, The Netherlands. A Remote Sensing company specialised in developing tropical forest monitoring systems.
> What are you using PostGIS for?
I do change detection on 35 daily radar images of tropical forests. The results of the change detection are raw polygons which I load into PostGIS to clean the layers and do some postprocessing with landuse and hotspot data. Results can be seen here:
http://www.sarvision.nl/projects/mawas/monitoring/ then click 'Launch VISION' button (you have to allow pop ups for www.sarvision.nl)
> Why did you choose PostGIS?
1. Because it runs on Linux and thus easily scriptable
> What makes you happy about your PostGIS installation?
1. It's robust
2. It's free
3. Active user community
4. For open source software it is quite well documented
> What makes you unhappy about your PostGIS installation?
some functions are rather slow compared to e.g. ArcGIS
hope this helps.
regards,
Arjen Vrielink
SarVision. Wageningen, The Netherlands
