[postgis-users] ERROR: Operation on two GEOMETRIESwithdifferentSRIDs
Johan V aragorn_jv at yahoo.com
Fri Jul 14 06:49:58 PDT 2006
Thanks that seems to work,
greetz,
Johan.
2006/7/14, Mark Cave-Ayland <m.cave-ayland at webbased.co.uk>:
> > -----Original Message-----
> > From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-
> > bounces at postgis.refractions.net] On Behalf Of Johan V
> > Sent: 14 July 2006 14:31
> > To: PostGIS Users Discussion
> > Subject: Re: [postgis-users] ERROR: Operation on two
> > Hi Mark,
> > Here are the descriptions of the tables (in the same database running
> > POSTGIS 0.8.2):
> > [database_x]=# \d reflijst
> >           Table "public.reflijst"
> >   Column   |       Type        | Modifiers
> >  artid     | integer           |
> >  titre     | text              |
> >  annee     | integer           |
> >  volume    | character varying |
> >  firstpage | character varying |
> >  auteurs   | text              |
> >  publica   | text              |
> >  strat     | character varying |
> >  domg_ol   | character varying |
> >  xlambert  | bigint            |
> >  ylambert  | bigint            |
> >  numcarte  | integer           |
> >  the_geom  | geometry          |
> > Check constraints: "$1" (srid(the_geom) = 103300)
> >                    "$2" ((geometrytype(the_geom) =
> > 'MULTIPOLYGON'::text) OR (the_geom IS NULL))
> > [database_x]=# \d gnosbgm
> >              Table "public.gnosbgm"
> >  id         | numeric(28,6)          |
> >  gemeente   | character varying(254) |
> >  x          | numeric(28,6)          |
> >  y          | numeric(28,6)          |
> >  z          | numeric(28,6)          |
> >  kaart      | character varying(254) |
> >  logdiepte  | numeric(28,6)          |
> >  bgdnr      | character varying(254) |
> >  bgdcode    | character varying(254) |
> >  refer      | character varying(254) |
> >  hotlink    | character varying(254) |
> >  imagepath1 | character varying(254) |
> >  logcomp    | character varying(254) |
> >  date       | character varying(10)  |
> >  tert_plio  | character varying(1)   |
> >  tert_mio   | character varying(1)   |
> >  tert_paleo | character varying(1)   |
> >  tert_eoc   | character varying(1)   |
> >  tert_oligo | character varying(1)   |
> >  primair    | character varying(1)   |
> >  secundair  | character varying(1)   |
> >  tertiair   | character varying(1)   |
> >  quartair   | character varying(1)   |
> > Indexes: sidx_gnosbgm gist (the_geom)
> >                    "$2" ((geometrytype(the_geom) = 'POINT'::text) OR
> > (the_geom IS NULL))
> > And the two sql statements:
> > SELECT the_geom FROM gnosbgm WHERE ((the_geom && 'POLYGON
> > ((33595.443392445566 15067.465440617714,281187.7093687274
> > 254932.5345593823,33595.443392445566
> > 254932.5345593823,33595.443392445566 15067.465440617714))'))
> > SELECT the_geom FROM reflijst WHERE ((the_geom && 'POLYGON
> > They are just the same, only the first give me the required answer!
> > Grz,
> > Johan
> Hi Johan,
> I think that the problem is being caused by the fact that in older versions
> of PostGIS, index scans ignored the SRID of the geometry during comparisons
> (they don't have a RECHECK clause) where as sequential scans did take them
> into account. My guess is that if you force an index scan on your reflijst
> table, your query will start to work. Can you try the following in a psql
> session:
> CREATE INDEX sidx_reflijst ON reflijst USING gist (the_geom
> gist_geometry_ops);
> VACUUM ANALYZE reflijst;
> SET enable_seqscan = 'f';
> 'POLYGON((33595.443392445566 15067.465440617714,281187.7093687274
> 15067.465440617714,281187.7093687274 254932.5345593823,33595.443392445566
> 254932.5345593823,33595.443392445566 15067.465440617714))'));
> Kind regards,
> Mark.
> WebBased Ltd
> 17 Research Way
> Plymouth
> PL6 8BT
> T: +44 (0)1752 797131
> F: +44 (0)1752 791023
> http://www.webbased.co.uk
> http://www.infomapper.com
> http://www.swtc.co.uk
> This email and any attachments are confidential to the intended recipient
> and may also be privileged. If you are not the intended recipient please
> delete it from your system and notify the sender. You should not copy it or
> use it for any purpose nor disclose or distribute its contents to any other
> person.
> postgis-users mailing list
