[postgis-users] Newbie installation question
luca marletta lucamarle at gmail.com
Mon Jul 17 13:44:22 PDT 2006
have a look here
http://wiki.beopen.it/postgresql:installazione
maybe you can find some hints
On 7/17/06, Øyvind Vestavik <oyvindve at idi.ntnu.no> wrote:
> Hi all
> I seem to have some problems with compiling with geos/proj-support on
> a ubuntu linux box with postgresql 8.1.1. I think I have been following
> instructions correctly, no compilation errors (as far as I can see), but
> still can't seem to get support for proj and geos in my installation:
> test=# select postgis_version();
>              postgis_version
>   1.0 USE_GEOS=0 USE_PROJ=0 USE_STATS=1
> (1 row)
>                List of relations
>   Schema |       Name       | Type  |  Owner
>   public | geometry_columns | table | postgres
>   public | spatial_ref_sys  | table | postgres
> This is what I did to install postgis:
> I installed geos and proj in default locations (/usr/local/)
> Snip:
> oyvindve at banditatwork:~$ which proj
> /usr/local/bin/proj
> snip:
> postgres at banditatwork:/usr/local/lib$ ls
> eclipse    libgeos_c.a   libgeos_c.so.1      libgeos.so        libproj.a
> libproj.so.0
> firmware   libgeos_c.la  libgeos_c.so.1.0.1  libgeos.so.2      libproj.la
> libproj.so.0.5.0
> libgeos.a  libgeos_c.so  libgeos.la          libgeos.so.2.2.1  libproj.so
> python2.4
> Then changed Makefile.conf to read the following
> USE_PROJ ?= 1
> PROJ_DIR ?= /usr/local
> USE_GEOS ?= 1
> GEOS_DIR ?= /usr/local
> make
> make install
> createdb test
> createlang plpgsql test
> psql -f lwpostgis.sql -d test
> Any hints appreciated.
> Kind Regards
> Øyvind Vestavik
> postgis-users mailing list
luca marletta
