[postgis-users] PostGIS kills all connections to the PostgreSQLserver
Paul Ramsey
pramsey at refractions.net
Wed Jul 19 16:06:12 PDT 2006
Great sleuthing Bruce!
I wonder if inserting a simplify() in there at some point would make
things even better.
P
Bruce Rindahl wrote:
> My guess as to why this is happening is the shapefile is really poor quality
> with intersections (interior loops etc.) Where did you get it? ESRI maps
> and data CD?
> The fix is to do multiple buffers. I tested your query and it ran in 234
> seconds (20000 buffer).
> I then ran:
> SELECT area(buffer(buffer(buffer(transform(GeomFromText('POLYGON((....
> ......))', 4267), 32039), 1000), 9000), 10000);
> and got the same result in 25 seconds. I think the first buffer in effect
> cleans out the weird parts of the shape and then the rest are acting on a
> cleaner shape. A 60,000 buffer was done in 26 seconds.
> Hope an order of magnitude helps!
> Bruce Rindahl
> postgis-users mailing list
