[postgis-users] updating points based on the poly they lie within
P Kishor
punkish at eidesis.org
Mon Jul 24 22:08:19 PDT 2006
I have been tinkering with PostGIS for the past few hours, and am
simply amazed by its capabilities (yes, I've been living under a
rock).
I have two tables, one of points (say, cities), and the other of polys
(say, states). I want to update the column cities.state_id =
states.state_id for the state it falls within. A little bit of
snooping around, and I got the following query working
SELECT c.gid, s.state_id
FROM cities c, states s
WHERE c.the_geom && s.the_geom
AND WITHIN(c.the_geom, s.the_geom)
which finds for me the state_ids for each city. A few newbie questions --
1. am I doing the right thing above?
2. what would the syntax be for updating c.state_id with the state_id
of the state it falls within? I am thinking something like
UPDATE cities
SET state_id = (
SELECT s.state_id
WHERE c.the_geom && s.the_geom AND WITHIN(c.the_geom, s.the_geom)
WHERE EXISTS (
SELECT s.state_id
Am I out of whack here?
3. Are indexes on the_geom enough to speed this up?
I have been reading the following point-in-poly thread
<http://postgis.refractions.net/pipermail/postgis-users/2006-March/011678.html>,
and it was not very encouraging speed-wise. However, I haven't
experienced major slow down yet. Besides, this calculation is to be
performed very infrequently, so speed is important but not super
important.
Many thanks in advance for all suggestions.
Puneet Kishor http://punkish.eidesis.org/
Nelson Inst. for Env. Studies, UW-Madison http://www.ies.wisc.edu/
Open Source Geospatial Foundation https://edu.osgeo.org/
