[postgis-users] updating points based on the poly they lie within
Gregory S. Williamson
gsw at globexplorer.com
Tue Jul 25 00:49:25 PDT 2006
It does indeed look like you are in the right ballpark at least.
You want to make sure you have a spatial (GIST) index on the relevant columns, both polygon and point. In earlier versions of postgres/GIS you had to run an explicit command [SELECT * FROM update_geometry_stats('table name', 'column name'); in newer (postgres 8.x I think, and postGIS > 1. something) the stats are updated with the regular "ANALYZE tablename;" command.
The bounding box operator (&&) in your queries hopes to get the planner to use the indexes. It may not use them anyway if you are trying to access a significant number of rows of the relevant tables (since 100,000 indexed reads are more disk i/o than a sequential scan of the table, if 100,000 is more than a tiny percent of your data).
I grabbed this example from a some code in a plpgsql function:
UPDATE raw_log_data SET fips = p_fips WHERE (req_pnts && sp_county_geom) AND (distance(req_pnts, sp_county_geom) <= 0);
The req_pnts are a column with point data and sp_county_geom is the area of interest. In this case we iterate through our areas of interest -- that turned out to be faster than trying to do all of them at once (think about 8000 polygons and some log files with a few million points)
The && does make use of indexes and the distance () test seems to be a bit faster than other methods of making sure a point is on or in a polygon.
HTH,
Greg Williamson
DBA
GlobeXplorer LLC
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net on behalf of P Kishor
Sent: Mon 7/24/2006 10:08 PM
To: Postgis
Cc:
Subject: [postgis-users] updating points based on the poly they lie within
I have been tinkering with PostGIS for the past few hours, and am
simply amazed by its capabilities (yes, I've been living under a
rock).
I have two tables, one of points (say, cities), and the other of polys
(say, states). I want to update the column cities.state_id =
states.state_id for the state it falls within. A little bit of
snooping around, and I got the following query working
SELECT c.gid, s.state_id
FROM cities c, states s
WHERE c.the_geom && s.the_geom
AND WITHIN(c.the_geom, s.the_geom)
which finds for me the state_ids for each city. A few newbie questions --
1. am I doing the right thing above?
2. what would the syntax be for updating c.state_id with the state_id
of the state it falls within? I am thinking something like
UPDATE cities
SET state_id = (
SELECT s.state_id
WHERE c.the_geom && s.the_geom AND WITHIN(c.the_geom, s.the_geom)
WHERE EXISTS (
SELECT s.state_id
Am I out of whack here?
3. Are indexes on the_geom enough to speed this up?
I have been reading the following point-in-poly thread
<http://postgis.refractions.net/pipermail/postgis-users/2006-March/011678.html>,
and it was not very encouraging speed-wise. However, I haven't
experienced major slow down yet. Besides, this calculation is to be
performed very infrequently, so speed is important but not super
important.
Many thanks in advance for all suggestions.
Puneet Kishor http://punkish.eidesis.org/
Nelson Inst. for Env. Studies, UW-Madison http://www.ies.wisc.edu/
Open Source Geospatial Foundation https://edu.osgeo.org/
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
!DSPAM:44c5a74a216985856016513!
