[postgis-users] Create spatial_ref_sys entry from srtext ?
Guido Lemoine
guido.lemoine at jrc.it
Fri Jul 28 04:26:48 PDT 2006
Is this not EPSG:31300 or 31370? Already in spatial_ref_sys.
GL
Arnaud Lesauvage wrote:
> Hi list !
> I received a bunch of shapefiles with a .prj file.
> I can't find the projection in the spatial_ref_sys table (it looks
> quite strange, it says "IGNBelg_Lam72").
> How can I insert a record for this projection in the
> spatial_ref_sys table ?
> Here is the .prj file content :
> PROJCS["IGNBelg_Lam72",
> GEOGCS["Hayford 1924",
> DATUM["<custom>",
> SPHEROID["International_1924",6378388.0,297.0]
> PRIMEM["Greenwich",0.0],
> UNIT["Degree",0.0174532925199433]
> PROJECTION["Lambert_Conformal_Conic"],
> PARAMETER["False_Easting",150000.013],
> PARAMETER["False_Northing",5400088.438],
> PARAMETER["Central_Meridian",4.367486666667],
> PARAMETER["Standard_Parallel_1",49.83333389],
> PARAMETER["Standard_Parallel_2",51.16666729],
> PARAMETER["Scale_Factor",1.0],
> PARAMETER["Latitude_Of_Origin",90.0],
> UNIT["Meter",1.0]
> Thanks a lot !
> Regards
> Arnaud
> postgis-users mailing list
