[postgis-users] determining intersection count
Bart van den Eijnden (OSGIS) bartvde at xs4all.nl
Fri Jul 28 06:29:22 PDT 2006
Hi list,
I want to determine with how many geometries in a table a certain
geometry (X) intersects. It works fine when I use:
SELECT count(*) FROM bestemmingsplannen.bouwvlakken AS b,
bestemmingsplannen.axel_v AS bp WHERE b.geometrie && bp.geometrie AND
intersects(b.geometrie, bp.geometrie) AND b.bouwvlak_id = 10 AND NOT
bp.naam = 'Axel';
so I select geometry X using bouwvlak_id=10.
Now I want to use GeometryFromText, but the count I get back is totally
different (12 versus 2). What am I doing wrong?
GeometryFromText('MULTIPOLYGON(((51603.74237044
365820.98748955555,51607.223759734 365821.15731342667,51606.459552328
365818.18539568223,51603.402722704 365818.8646911667,51603.74237044
365820.98748955555)))', 28992) && bp.geometrie AND
intersects(GeometryFromText('MULTIPOLYGON(((51603.74237044
365820.98748955555)))', 28992), bp.geometrie) AND NOT bp.naam = 'Axel';
I verified I am using the right geometry by using the following query:
select AsText(geometrie) from bestemmingsplannen.bouwvlakken b where
b.bouwvlak_id = 10;
the result is:
astext
"MULTIPOLYGON(((51603.74237044 365820.987489556,51607.223759734
365821.157313427,51606.459552328 365818.185395682,51603.402722704
365818.864691167,51603.74237044 365820.987489556)))"
Thanks in advance.
Best regards,
Bart
OSGIS, Open Source GIS
http://www.osgis.nl
