[postgis-users] determining intersection count
Arnaud Lesauvage
thewild at freesurf.fr
Fri Jul 28 07:03:27 PDT 2006
Bart van den Eijnden (OSGIS) wrote:
> Hi list,
> I want to determine with how many geometries in a table a certain
> geometry (X) intersects. It works fine when I use:
> SELECT count(*) FROM bestemmingsplannen.bouwvlakken AS b,
> bestemmingsplannen.axel_v AS bp WHERE b.geometrie && bp.geometrie AND
> intersects(b.geometrie, bp.geometrie) AND b.bouwvlak_id = 10 AND NOT
> bp.naam = 'Axel';
> so I select geometry X using bouwvlak_id=10.
> Now I want to use GeometryFromText, but the count I get back is totally
> different (12 versus 2). What am I doing wrong?
> bestemmingsplannen.axel_v AS bp WHERE [...]
I believe it is because you forgot to include 'WHERE b.bouwvlak_id
= 10' in the last query.
If you don't mention that, all rows of b times the rows of bp
matching your criteria will be included in the count.
Regards
Arnaud
